Street Racing & Kill Stories Basic Technical Questions & Advice
I have a short older "kill" story~
Old 12-16-2010, 09:43 PM
  #361
Mystic Z-28's Avatar
Originally Posted by The Manalishi
You don't know what you are talking about. I've had LT1 and LSx cars and the LT1 would hold its own, you have to approach it a bit differently. Hell the LS1 seems to pick up power if you fart next to it. The LT1 takes a little more knowledge and a lot more patience.
If a stock or similarly modded LT1 holds it's own against a stock or similarly modded LS1. The LS1 has problems, that's all there is to it. The last LT1 that i raced put down 280 rwhp, and also has a 6 speed with 3.73 gears. Needless to say I laid waste to him pretty easily. He got me off the line only because he had DR's to my street tires. Then I pretty much passed him like he was standing still. Pulled about 4 cars on him from 40 to 80, once i got traction. That same LT1 also pulled the same 3 valve that i raced, and a few others he says.
Mystic Z-28 is offline
  #362
WSsick's Avatar
Originally Posted by Stopsign32v
I'll believe it when I see it. If I remember correctly you are goofy looking guy with glasses. Not that there's anything wrong with that..
You're damn right there isn't. Let's keep that mindset so I don't knock your Blue Oval humping *** the **** out.
WSsick is offline
Old 12-16-2010, 09:51 PM
  #363
The Manalishi's Avatar
I will promise you that you could build a heads and cam LS1 and I could build a heads and cam LT1 that would embarrass you.
The Manalishi is offline
Old 12-16-2010, 09:56 PM
  #364
WSsick's Avatar
Loser gets teh
WSsick is offline
Old 12-16-2010, 09:58 PM
  #365
Tech Apprentice
Stopsign32v's Avatar
Originally Posted by Irunelevens
I really am confused... I know that's not you because it's different than the Integra in your avatar. But did you actually get an Integra or not?
Yea I got it back in Oct. Its a 97 LS with 85k miles. Milano Red with black interior and 5 speed. Here it was after I bought it...
https://ls1tech.com/forums/14086085-post57.html
So far I've done timing belt/water pump, AEM SRI, 5k HIDs, Enkei RPF1's 16x7 35 offset, and Ground Control coilovers on the way..should be here Monday.
Oh and I've got a turbo waiting to go on too. That is after I lower it.
Stopsign32v is offline
  #366
Well duh. If were talking H/C/I builds, since that's the only real difference there is between an LT1 and an LS1. Obviously not all H/C/I set-ups are the same. I was mainly talking about basic mods. Or cam/bolt-on only cars. Sorry for the misunderstanding.
Old 12-16-2010, 10:01 PM
  #367
Originally Posted by WSsick
Loser gets teh
If he builds his own heads and cam LS1 with no input from a professional and beats the LT1 car not only will I accept a ban I will burn the LT1 car and post the video. I guess I should start looking for an LT1 car. Maybe I could just put an LT1 in my third gen.
Old 12-16-2010, 10:05 PM
  #368
Its all good. Just so you know there are a lot more differences between a LS1 and LT1 than just H/C/I. They share nothing except they are both GM engines.
Old 12-16-2010, 10:09 PM
  #369
Old 12-16-2010, 10:16 PM
  #370
sujomatt's Avatar
sujomatt is offline
Old 12-16-2010, 10:17 PM
  #371
WSsick's Avatar
LT1s are actually pretty cheap. I saw one locally a while back for $500, with a small cam & VT ****. Good deal if anyone is looking for cheap power.
Wrong. They are both V8s.
WSsick is offline
Old 12-16-2010, 10:18 PM
  #372
WSsick's Avatar
Holy random pictures.
WSsick is offline
Old 12-16-2010, 10:19 PM
  #373
Good one, DICKWEED! LOL
  #374
sujomatt's Avatar
sujomatt is offline
Old 12-16-2010, 10:21 PM
  #375
WSsick's Avatar
I'll just pretend you didn't add that last part, old geezer. Shouldn't you be in bed? You need to pick up your SS check in the morning.
WSsick is offline
  #376
sujomatt's Avatar
sujomatt is offline
Old 12-16-2010, 10:23 PM
  #377
WSsick's Avatar
Mystic, to redeem yourself, you need to take out the GTP and race it against your catfish. Obivously you will need to find (make?) a friend to do this.
Post results.
ALSO, matt is one weird ************. Original powerrangers was the best. It never should have ended. Saw it live one time, pinnacle of my life....at age 5.
WSsick is offline
Old 12-16-2010, 10:24 PM
  #378
marc97taws6's Avatar
Originally Posted by clint195
Not all Nebraskans are like that just the ones from Norfolk.
Race my POS then. And btw, Clint actually doesn't own a POS 4th gen like us
marc97taws6 is offline
Old 12-16-2010, 10:28 PM
  #379
sujomatt's Avatar
UNTZZZZZZZZZZZZZZZZZZZ !!111!11!1one!!1one!one
sujomatt is offline
Old 12-16-2010, 10:29 PM
  #380
WSsick's Avatar
^bbofrihes
WSsick is offline
Quick Reply: I have a short older "kill" story~
