???Mustang vs Cammed Camaro
#41
1 Post
I guess so, is it not a 6.0l
Yes, it is a truck block,is there a difference? I was told I could get better stock heads than whats on the car, but being a student cash is hard to find laying around. They were hand rubbed, and going from a stock Ls1 head using the same valves I gained 20rwhp on the dyno, only cost me $300. If some one wants to donate a pair of aftermarket heads I'll try them.![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
So what heads are on there, 317's (6.0) or LS1?
#43
By who? You perhaps ? ![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Ditto.
This.
This too.
Yeah I lost respect for him long ago. Like Unit says, he is on a high horse!!!
Wow, and name calling too. Dude you're the only one on your side okay? Get used to it.![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
quick edit: Judging by the bolded word, I think pot has met kettle![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Ditto.
This.
This too.
#45
Odorbala my offer still stands. Take a "iron LS1" which is really a LQ4/9 and take all the bottom end out of an aluminum LS1 and if it all buttons up with no machining and I will suck your dick. A LS1 is a 5.7 and this iron LS1 is a 6.0 tell me how they are the same thing. As I already said in my first few posts they are all Gen 3 small block V8 that is the only similarity.
#47
I actually sort of understood what he was saying at first, but then as usual he always takes it too far imo. Oh well I guess communication comes across all wrong on here sometimes, no big deal lol.
#48
I wasn't trying to be rude. I thought everyone knew that wikipedia was user edited.
LS1 is an engine designation, as is LQ9. They are both in the LS family. Here is an article that breaks it down. You could also look at the Scoggin Dickey catalog which sells GM crate engines. While it is COMMON for lq engines to get falsely called ls1, it is still not correct.
http://www.chevyhiperformance.com/te...son/index.html
#49
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#53
Btw Odarabla you have that link posted to Texas-Speed that has the LS1/LQ blocks in 402-408 ci neither of which are stock cubes for them. Which is what our discussion was about this whole time. Just thought I'd let you know.
#54
But I will fix that, Bought a NX kit and just gonna spray the Pee out of it
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I think the are the 317 heads. It had Ls1 stock heads till I got the deal on the 6.0L I couldn't afford valves so the heads have stock LS1 valves.
#55
Ok, see I did't know that fact, and I did not want to call it a LS1 due to being called an Idiot when people found out is was a 6.0L. Now I am wondering if I built a turd ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
But I will fix that, Bought a NX kit and just gonna spray the Pee out of it![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
I think the are the 331 heads.
#56
#57
What does this have anything to do with it? Your right it isn't a stock cube engine but the LS1/LQ9 iron block is the same reference because it started as a New GM stock block before they bored it out.. Still referring to it as a LS1/LQ9 iron block.. But I will be sure to call them to let them know they are wrong to..
#58
http://www.chattanoogan.com/articles/article_167228.asp Just for S&G
At 1.04 you see the car with the stock LS1 heads vs a Full bolt-on LS1 car (when the car was running good.)
At 6.06 the car ran a 347 fully built mustang (I was told it made 680 to the crank
) not sure but the stang won by a car.
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
#60
The iron 6.0L truck block is a LS1 Iron block. The LS2 is an alluminum block and it is completely different than that iron block you have.. Change your sig to Iron LS1 block..
Not trying to be a dick man but I just lost a little respect for you becuase of your last few post. I always took you for someone who knew what they were talking about.. Now not so much..![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
edit: You also said it is "known as a ls1 iron block" which it is not. It is known as the lq block, which it is. Just because something is similar to something else doesn't make it "known as" the same thing. Stupid argument anyways and I think everyone knows what the other is saying so **** on it.
