Fun in my Girlfriends Z28: z28 vs 11' CS/GT
#62
LOL...I love how you are like ls1/ls2/ls3/ls6...lol..You forgot ls7 just to make sure you win..haha.
And you will see a 5.0 hit 600whp. With new cams that are out and the Boss heads released and others doing work on heads. Its a matter of time. The high compression is also a key on it as well. Stock compression is 11.5:1.
#63
What does that have to do with 5.0 blowing up? I can see bad lifters,but when you have a certain #8 cylinder failing on every single 5.0 that has had a failure that is a problem with design and not a defective part..
#64
Haha. I love when threads go out of track. It's funny. I've ran 2 new 5.0's and didn't loose. So I think they both suck at driving and I'm the best driver ever. So I guess that's what's gonna win, driver. I also think the pony needs more horses to pull away from an LS. Im sure if my GF Camaro and the new 5.0 made excact same WHP the Camaro will pull away due to the gearing. I don't think 373's are helping out the stang much. Unless it's on the track.
#66
Its not ford's fault guys are running them to lean and doing half *** email tunes.
#67
Second you must be really stupid to racing if you think the gears are not helping the car. That and think a stock LS is going to beat a 5.0. You beat the driver. Big difference then beating the car. Full bolt on and cammed LS's and a stock 5.0 sure i see it.
#68
Every 5.0? There has been a total of about 8 out of the 15k sold. What is better from has leaked out two shops tuned them all. Bruenspeed and BAMA. It is in the tune. The way they change knock sensors and stuff. Livernois/Jon Lund/evoperformace/BlwoBYRacing and had no issues with thier tunes blowing up cars.
#69
quote where i say that anywhere? u r simply butthurt.
tuners blew those motors is not a defect. you also dont know that 804rwhp has been achieved with a stock engine, top to bottom and blower, on race gas.
#70
#71
Are you that stupid? You do know the 5.0 is over 11:1 compression ratio,so how in the hell are they putting out over 800rwhp on stock internals with FI? No way in hell they are pulling those kind of number with that kind of compression..lol
#72
well, if im stupid, you are a fool. wake up fool.
#73
There first video I know that guys. He ended up running the car to a 12.6 stock. That video was also in middle of summer with a DA of 3k. Car has now went low 11s also.
Oh he also traded a 09 SRT8 chally/10 CAMARO SS/10 GT500(wifes) in that order to get his 5.0 and his wife a 2012 Chally RT(it had more room then the GT500).
And since you first one to run a 5.0. That shows that guy didnt even know how to drive his car.
If you are really that stupid and think the 5.0 isn't going mid to low 12s stock you are dumber then I thought.
#74
Better do your research cause they are. Shops, regular owners all. With KB/Whipples/Prochargers?vortechs/and paxtons.
http://www.dragzine.com/news/video-j...akes-800-rwhp/
600whp with pump gas and no other big mods
http://www.modularfords.com/forums/s...-Final-numbers
672whp with pump gas
http://www.s197forum.com/forum/showthread.php?t=48591
I can keep going also.
#75
#76
http://www.youtube.com/watch?v=yXuCBFVF2XY
there you go.
your expertise on the internal strength of the coyote is lacking. IT IS FAR STRONGER THAN A STOCK LS.
you are obviously basing your coyote 'knowledge' on internet BS. you also have no idea that guys running renegade EFI are running 10:1 and big boost with YSi blowers.
there you go.
#77
Did you cherry pick those 5.0 runs and skip past the ones that were better? Just curious because when I check youtube I see alot in the 12's and alot in the low 13's when searching "stock 2011 5.0 drag". I won't say what I saw searching "stock ls1 drag" because it wasn't pretty.
I wouldn't say I'm a nutswinger for ford. I'm just realistic.
Also, good kill OP but it does seem fishy. Maybe the 5.0 had a trunk full of dead hookers. Not that I have been there or anything
#78
Its funny you say you beat them. Yet in your GF's car 90% people here with same car calls BS. HAHA
#79
Its actually has 11.5:1...and think the Camaro SS is 10.5:1..not much different.
#80
