Street Racing & Kill Stories Basic Technical Questions & Advice
Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
Old 06-19-2014, 12:41 PM
  #37921
wooddaniel's Avatar
Sup fools. I started outprocessing today. Can't ******* wait to get the **** off this island.
MAC 650$ is a little steep unless they are absolutely flawless with new tires. Somewhere in the middle would be a good price.
wooddaniel is offline
Old 06-19-2014, 12:49 PM
  #37922
"MAC"'s Avatar
Yea i priced high n have plenty of negotiating room in it. That way i can get the most for it. Im thinking $475 to $500 is bottom dollar. So if i get more ill be happy.
"MAC" is offline
Old 06-19-2014, 01:27 PM
  #37923
S8ER95Z's Avatar
Originally Posted by SoFla01SSLookinstok
I am actually looking at a kit right now you may be interested in. This is the fuel pump I am going with pretty soon. The Racetronix kit i'm referring to says will support 600rwhp & with the pump booster connector set it says will handle 700rwhp. I also like the Racetronix pumps because they keep the venturi system. Check em out!
I have the racetronix pump...pretty easy to install and no complaints from it. It's been in there around 3 years iirc... (just shy of 60,000 miles on it now). I picked mine up from WS6Store and it's red so I think it's their 'mild' pump (no idea how to confirm that)... this appears to be the 600+ pump.
http://www.racetronix.biz/itemdesc.a...2D001B&eq=&Tp=
The one I bought is here.. which leads me to believe those are the boosted numbers and the lower end pump. The one above should boost beyond 600rwhp
http://www.ws6project.com/user_stor/...oducts_id=4032
Tests in the field have proven the Racetronix F99+ system will support upwards of 600RWHP and 700RWTQ in some applications.
S8ER95Z is offline
Old 06-19-2014, 01:48 PM
  #37924
SoFla01SSLookinstok's Avatar
Awesome! I'm glad to hear good feed back about it. Thats the pump, i'm going to get it with the wiring harness as well. TSP has a good price on them. http://www.racetronix.biz/customkiti...RFPK%2D001&eq=
SoFla01SSLookinstok is offline
Old 06-19-2014, 01:52 PM
  #37925
http://www.texas-speed.com/p-2358-ra...ic-system.aspx
Old 06-19-2014, 02:41 PM
  #37926
High quality drive line components!http://www.promotionpowertrain.com/
Old 06-19-2014, 03:31 PM
  #37927
ZNix's Avatar
Picked up a set of Nitto NT555r DRs from Evan. Mounting them to my cheap aluminum rims. I'll have pictures up soon lol.
ZNix is offline
Old 06-19-2014, 04:01 PM
  #37928
StealthFRC's Avatar
come to the track with us saturday?
StealthFRC is offline
Old 06-19-2014, 07:22 PM
  #37929
Blown383LS1's Avatar
Damn, just found out I have to drive to PA to work for awhile. It's only 1100 miles away, lol. I will be working in the SW corner of the state, and going into Ohio and WV too. What is there to do around that area?
Blown383LS1 is offline
Old 06-19-2014, 09:21 PM
  #37930
Gt4urass's Avatar
Run Hio.
Gt4urass is offline
Old 06-19-2014, 09:35 PM
  #37931
Originally Posted by Gt4urass
Run Hio.
I think he has my 2011 2500HD covered. It is a crew cab with 4wd too.
Old 06-19-2014, 09:59 PM
  #37932
"MAC"'s Avatar
So im wondering if 16" arms are still considered small? I measured my arms for the first time in my life and thats how big they are when i flex. I think i still have small arms and tryn to get bigger and stronger. Mr. Daniel and anyone else that works out am i right? I started running again as well for the first time any advice on not getting shine splints? I ran/walked a mile in 9:27 today which is pretty good imo for not running for 3+years.
Sry im 6' 2" i know arm sizes will look big or small depending on how tall you are.
"MAC" is offline
Old 06-19-2014, 10:35 PM
  #37933
ZNix's Avatar
Help! What size front runner? Weld RTS wheel, don't know what width. I drive this car on the street daily. I was thinking a Sportsman 215/70/15..
ZNix is offline
Old 06-19-2014, 10:40 PM
  #37934
Poppacapp's Avatar
First experience with an is350 this morning... UNDERRATED.. I'll leave it at that.
Yep, I had one. Ran 8.40's in the 1/8th @85mph. They have 4.09 rear gear with 6 speed close ration tranny. They get up to 80mph pretty quick. I wasted quite a few V8 cars that would have not expected it.
Poppacapp is offline
Old 06-19-2014, 10:41 PM
  #37935
Poppacapp's Avatar
Originally Posted by audacious nick
Lol. High 13s and you're surprised?
mid 13's bone stock. Low 13 with exhaust and cold air only.
Old 06-19-2014, 10:43 PM
  #37936
Gt4urass's Avatar
Good luck getting off the island mang.
Gt4urass is offline
Old 06-19-2014, 10:45 PM
  #37937
Gt4urass's Avatar
Whether or not they look big is largely dependent on how the rest of your body is built. 16 isn't a small arm, but on your relatively tall frame, they won't appear quite as impressive as they would on a shorter dude. It takes a while to add girth to longer muscles. Keep it up, sounds like you're off to a good start,
Gt4urass is offline
Old 06-19-2014, 10:51 PM
  #37938
"MAC"'s Avatar
Thanks man i had one of those look in the mirror and wasn't happy with how i look moment's. So i decided to start running again and wanted to lift more often.
"MAC" is offline
Old 06-19-2014, 10:54 PM
  #37939
ZNix's Avatar
16" arms are probably kind of small on your frame... I have 18" arms and they look small on my frame (5'10"). I used to be a lot stronger, lately I feel weak. Need to start lifting weights again.
ZNix is offline
Old 06-19-2014, 10:55 PM
  #37940
Gt4urass's Avatar
No problem. It's a balancing act that's sometimes difficult to figure out if you're trying to lean up while maintaining size. Just try different things and see what works best for you. Everybody is different.
Gt4urass is offline
Quick Reply: Odarabla's infinite BS thread for the foreskinned (AKA Smack Down)
