Raced a Rear mount Turbo Z28 with my 03 cobra... He a member of these boards?
#61
VA Speed has taken LS2 blocks to 1,800hp before. The reason, at least from what I've found, that most people go to iron blocks is because they think the aluminum can't take it, when really it's the internals that 95% of people should worry about. The block can hold 1,000+, but most people aren't making that kind of power. Pistons, rods, rings, bearings, etc. is where you get into trouble. Not to mention, the truck motors have lower compression than an actual LSX motor, so that's always a plus.
#62
I know i saw the picture before i posted. Just the perfect time to bring the sarcasms to life. As i write this though i must admit. I probally get more excited when i see that 03 body style with cobra written across the back than when a I see a gtr or z51 ls3 vette. It has an amazeing road prescence for a sub 40k car. This is somthing only americans are able to do. What sub 40k foreighn car gets you as pumped as a cobra? Ford actually did somthing right
#63
anyone doubting that an LS1 can hold boost reliably needs to take a look at my car..it's had a procharger on it running between 6-7 psi since 2003!!!! so yeah like 9 years and it's still going strong..not to meantion had the stock 10 bolt beaten on by myself with over 100 passes all in the 1.6 60ft range with stock 3.23 gears as well as the previous owner before me (who was the one who added the procharger) he beat the **** out of my car as well...i have replaced the 10 bolt with a Moser 12 but only because i needed gears and it made no since to put money into a 10 bolt at my power level..point being..LS1 F bodies are very stout cars in nearly every way..with a good tune 10 psi on a stock LS1 should'nt be a problem
#64
If you rolled up on me on the street; you would surely think that Cobra's are over rated.
I roll on the street with Sumitomo's on the back of my car (my car is a true DD), and most slow cars would pwn me on the street with those hard *** tires on it.
As far as being around me in person; I have a dry sense of humor and some like it, and some don't (say that I come across arrogant).
#65
Very true, however, I believe that a mediocre front mount setup is probably better than most off the shelf STS kits out there. Zombie is an exception to that generalization. Isn't zombies setup a stalled auto? It's not common for guys to keep a 6 speed for a turbo setup. Most guys will switch out to a TH400 or built 4l80e/4l65e. Procharger setups seem to be the route most 6speed guys go.
STS is cheap however.. I have seen complete kits sell for 2,000-2,500$ on here.. Granted you will put another grand in it, 3,500$ is not bad for a FI turbo setup that will be able to do very good in the right hands.
6 speeds should stay away from snails, they need to go blowers. Stalled a4s dominate with a snail.
Yes, he switched from a 6 speed to a stalled auto, dropped ET and raised MPH.
#66
Ls1 blocks can hold a nice bit of power.
Properly set up rear mount lag is extremely small. Set it up with pacesetter LTs/6 speed/etcetc and sure, it will take 5 seconds to spool.. Build something like Zombies, you won't be able to hardly tell a difference between his and a front mount.
STS piping blows dick, the turbo that comes with the kit is quite nice however.
#68
#71
Oh and to the op. 520whp on 4psi is complete bull, that car had no pull what so ever. good kill on sombody that just spent money on somthing he dosent know **** about lol.
#72
Some people would spend twice to learn once, rather than learn first and spend less, I guess. I still wouldn't go with a rear mount with all the options available out there these days.
Just my opinion. But I always thought a good rule of thumb is to keep **** close together, when it comes to snails. Not way the hell out back like that...
