Street Racing & Kill Stories Basic Technical Questions & Advice
He couldnt leave me alone......
Old 01-19-2012, 10:12 AM
  #201
92cobranotch's Avatar
Originally Posted by Mike Morris
LOL
Kevin or Nathan know anyone running a B-31HR Camshaft? I think it might be worth it for my Fox body(331 with 20 pounds of SC boost) over the Trick Flow stage 2.
do you know when Fast is Fast enough? lol Sounds like a lot of work for small gain. I would think 40hp at very max max. ill find some specs on it and take a closer look but i think bite mark may be correct depending on specs
92cobranotch is offline
Old 01-19-2012, 10:15 AM
  #202
88blackgt's Avatar
Originally Posted by HioSSilver
You guys keep hoping that.
You do realize how similar an LS and SBF are right? Lol the similarities and them being so close is the reason I joined this forum.
88blackgt is offline
Old 01-19-2012, 10:30 AM
  #203
why87's Avatar
Originally Posted by 88blackgt
You do realize how similar an LS and SBF are right?.
uhhh.....they're both pushrod?
*edit-after doing little online research I'm still not convinced.
why87 is offline
Old 01-19-2012, 10:37 AM
  #204
lol exactly.alot of ls stuff is aluminum block. sbf has never came with a good flowing head. ls stuff you can keep headgaskets on them. not good comparison for ford, beter keep comparing new 5.0 to ls makes ford look beter
Old 01-19-2012, 10:40 AM
  #205
Need_a_Camaro's Avatar
I love the Ford diehards that come to this site and preach their bullshit. I've never looked, but I assume there's sites dedicated to Fords?
Need_a_Camaro is offline
Old 01-19-2012, 10:58 AM
  #206
Mike Morris's Avatar
If 40HP is to be gained from that cam swap I am in it for it. I just wonder if my cam is holding me back....
Specs for TFS stage 2
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 232
Duration at 050 inch Lift 224 int./232 exh.
Advertised Intake Duration 293
Advertised Exhaust Duration 290
Advertised Duration 293 int./290 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.542 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.563 in.
Valve Lift with Factory Rocker Arm Ratio 0.542 int./0.563 exh. lift
Lobe Separation (degrees) 112
Mike Morris is offline
Old 01-19-2012, 11:13 AM
  #207
looks like most are 110 centerline,114 lsa, 230s duration. id like to know the specs on the one your considering.
Old 01-19-2012, 11:15 AM
  #208
B-31HR 218/228 .576/.576 w/1.6 rocker 275/284 112 107
These guys did my heads and I am running a honed Holley Intake with 1 3/4 Bassini full lengths
Old 01-19-2012, 11:22 AM
  #209
here are the specs.AFM B-31HR 218/228 .576/.576 w/1.6 rocker 275/284 112 107 damit you found them right before me
Old 01-19-2012, 11:26 AM
  #210
I would get a ed curtis custom grind looks like it would benifit alot more especially on a 114 lsa and get in the low to mid 230s duration but ask him what he suggests
  #211
Kevin posted it earlier
What do you think?
Old 01-19-2012, 11:31 AM
  #212
What do you think?
i think you want more intake duration at your boost level and a 114 lsa but i would talk to rick at afm or ed curtis. explain your exact set up to them
Old 01-19-2012, 11:43 AM
  #213
HioSSilver's Avatar
There are Ford site's Donnie. They get together and go to the dragstrip and all. The problem is that some of the Ford guys get bored of waiting for their Ford brotheren to finally reach the end of the 1/4 (some even fell asleep)....the ones that got bored ended up here.
HioSSilver is offline
Old 01-19-2012, 11:46 AM
  #214
There are Ford site's Donnie. They get together and go to the dragstrip and all. The problem is that some of the Ford guys get bored of waiting for their Ford brotheren to finally reach the end of the 1/4....the ones that got bored ended up here.
im gonna show you bored.
Old 01-19-2012, 11:48 AM
  #215
HioSSilver's Avatar
Your gonna need more boost
Old 01-19-2012, 11:50 AM
  #216
not what i have in mind mike: i want your tfs cam for 50 dollars lol perfect for fairmont.
Old 01-19-2012, 11:51 AM
  #217
HioSSilver's Avatar
Ok then....you'll need a second power adder
Old 01-19-2012, 11:54 AM
  #218
Originally Posted by hiossilver
ok then....you'll need a second power adder :d
Old 01-19-2012, 11:57 AM
  #219
you get your car done yet?
Old 01-19-2012, 01:28 PM
  #220
RON 95ZR1's Avatar
hmm...Good point.
ET Performance makes a great product. I have a set of their 11* 255cc LS1 heads going on to my sleeved 415-inch LS1. Their pricey though. lol
RON 95ZR1 is offline
Quick Reply: He couldnt leave me alone......
