03turbomach1 vs built honda 500+ whp
#61
Civic- 545hp 2400lb
I don't believe that he didn't turn up the boost. It just doesn't make sense.
#65
H4RD, the Mach most likely got his power to the ground. I highly doubt this 2400lbs fwd Honda was getting anywhere near 545hp to the ground on the street. If both got the power to the ground the Honda would trap 25+mph higher.
#66
you just said the honda would trap 145+! are you feeling ok?
#70
#71
would have put several busses on said mustang.
#72
#73
i heard of a local honda here making 550ish whp and weighing in around 2200lbs (not sure raceweight or wo driver...driver prob weighs 120) and it trapped mid-high 140s
any honda making 500+ whp is going to skullfuck a 440whp 3200+lb car, peaky powerband or whatthefuckever. there was clearly something wrong with the car in this video, it should have made swiss cheese out of that muffdain.
#74
#75
lol its grabing ok so far. you can come drive mine when hiho gets ls7 in. then you guys can run. that makes it worth the trip.
#78
Not trying to make excuses, but my clutch in my Cobra is slipping at the track and that is the only place I race.
I want a Mcleod RXT to put back in it...but I can't rationalize spending that kind of money when I just put this Centerforce dual friction in it last summer
![Argh](https://ls1tech.com/forums/images/smilies2/argh.gif)
#80
twin disc is probly the only way to go at your power level. i have a spec but dont know wich one. (it was in the swap when i got it).
