Death to HioSSiver!!
#201
Your car runs really well, I'll never deny that. I love that I could read your entire response without using Google Translate. Thank you for that
...and why would I be "hurting" because your car runs well? When did I even mention a Ford in any of my responses to you? (on the nutswinging comment). You're like a broken record...someone says something you don't like and it's nutswing this Ford that...get some new material, doll...man you're just all ate up about them Blue Ovals
Sure I do. I was just at a ford club track rental on sat. Ask notch what the 2 most impressive cars were that day........lmao.....
#203
#207
#208
#211
#212
ok. motor is out pan is off. i can see the pan hit the pick up tube where the dent is. so far it looks like this could have caused it to oil starve. ill get pics tomorow when i do further disassembly. **** me cant believe i missed this dent in pan.
#213
Damn, that's crazy that you missed the dent in the oil pan.
Maybe you can get away with replacing the bearings and a new oil pan.
#214
I yanked my balancer with a standard cheap balancer puller that I've owned for probably 20 years now.
I think you're talking about the Supercharger crank pulley key. google the metco installation instructions and that should walk you through it. I don't remember what size it is.
#218
That's how. Do you think I'd be serious if I spelled Camaro "Camero" out of the blue?
#220
Not bad news. IMO you need to take the oil pump apart and inspect it for galling. And pull the cam caps off and inspect for galling of the bores or scaring of the journals.
Don't want to put it back together and lockup a cam.
