intake only 2006 GTO vs eaton swapped Mach 1 **VID**
#922
I have done it and seen it.
SRT8's stock trap 108-110
Mach's stock strap 105 or less
a bolt on mach 1 vs stock an SRT8 is a drivers race...
http://www.youtube.com/watch?v=qEzxyq3Vfho
jk..
#924
No you misunderstood me. What I said was me driving a M5 stock Mach 1 would pull a stock SRT8. A stock SRT8 against me now would be hilarious from any roll until I ran out of gear.
#927
suckadickbitch.ooooo
#928
#929
Bottom line is he runs 12.6 or 12.5 or w/e @108 thats nothing special. For him to say he can beat Me, GTO's, and 5th Gen SS's with a 108 trap speed is dumb. Sure he may be able to out launch a rookie driver with his 4.56 and drag slicks but against someone like me he will get pulled. 108 isnt enough plain and simple.
Nix
#930
And the 1000rwhp Mach 1 stock block hasn't blown up.
#932
#934
Actually its alot harder for the simple minded. If you think you could get in my car and run the same times as me you are stupid. You wouldn't have a clue on what the first step is. And I dont drive my car in D by the way I use auto stick mode.
#936
Define full weight bigs n littles are considerd full weight nowadays for the most part. Nobody said anything about weight just becasue you drive around in a tank does not mean a lighter car with some weight out is a tin can racecar
#937
He is going to put the driver mod behind his SRT8 with street tires and his stock stall against me on 15x10s and launching off the moon. He's awsome
#938
#940
