Can only gto vs Cammed sprayed Mach 1
#141
Well I can only say what I have seen first hand and that is bolt-on 2vs running 12s close to full weight. With cams and a small shot it ran 11.5 @ 117.It is now a nitrous car and makes 52x. I have see a cams only auto 2v trap 111.xx at 3500lbs. With a small turbo on 5lbs it wen low 11s at 122+. On 8lbs made 45x and beat a whipple cobra that has been 128. On 12lbs ran with a vortech boss that has been 136. So I know what they can do in the right hands.
#145
#150
#156
Far and few between. 99.9% go bottom 13s with every bolt-on possible. Been there, done that. Hell most bored block, heads/cams/ported intake/full bolt-on geared cars will be lucky to see bottom 12's. Without built motor/FI a 2v is nothing to talk about.
#158
***Repost Police***
#160
That's not what I am implying. I too was a 2v owner once long ago. Seeing as you've had experience with them I don't need to go into detail about how they are, by no means, the ideal power plant for a N/A build. However, as I stated in my last comment, with FI and worked shortblock they can make noise.
