Stock C4 Corvette (M6) vs 2012 V6 Mustang w/catback + tune (A6)
#42
I'd love to see how he'd do against a well maintained, well driven LT1 vette from a low roll. He should have a slight power advantage, but the vette weighs less and a manual would have an advantage.
#43
Like Marc said, 1994 Z28, A4. He's got most of the bolt-ons. The only other power bolt-ons he could so would be swapping the shorty's for long tube, swapping on a larger throttle body, and a tune. Gears and a converter would help quite a bit, but he's going in a different direction with the car.
#45
1 Post
#46
#47
Yeah, stock internal, other than 1.6 rockers. He has 3.42 gears, but the taller tires knock the gearing back to around stock.
#48
#50
(Nice. I've been researching a lot lately, I'm glad you verified that this is a good cam. What else do you have done to your car? Also, what valvesprings are you using?)
I have hooker comp long tubes, ported. Throttle body, cold air intake, 1.6rr's, xfi 466 cam, off road y-pipe, magnflow muffler, comp cam "beehive" valve springs, t56 built by liberty, 4.10 gears and an s60
#51
Where do you shift? I've heard mixed things about the CompCams beehives, how do they handle higher rpm's? Any reason why you didn't go with dual-springs? I'm just wondering
#53
#54
I`m going to get my heads done an figured might as well lol. the way my car sits it ran 12.46 spinning 1-3 on almost shot M/T drag radials an it was 45 degrees out lol
#55
It's not a difficult job, you just have to adjust them correctly. The first time I ever did it (10 years ago) I fucked it up and bent a bunch of pushrods. I would do valve springs at the same time, although I have heard of people reusing the stock springs.
#57
Alright thanks. I don't know too much about modding yet, but I'm trying to learn before I go do it. What ratio rockers are you running? I've heard of people running 1.7's in LT1s. Also, what are the springs you're using called exactly? Are they CC 918's?
#59
Cool, good luck with the assembly, I'll def be taking a look at your build thread, especially the heads
