Big Single Supra
We did it again just to make sure it wasnt a fluke. Both times on video.
That "trademark single WAAAA PSH" ... could have just been a loud aftermarket blowoff valve... nothing more. That sound is no indication that he's got a "big single" under there.
...Musclemonte - why would you make a generalization like that about a particular car owner (in this case, a Supra owner)? Makes no sense... especially since the post did not clearly articulate anything factual about the person.
it certainly is.... especially since I own a TT Supra which is essentially BPU (including the stock turbos) which pulled a 117 MPH trap in the 1/4.... [Assuming you were being sarcastic there, Iv_z28].
So now where are those videos, Venkman?
Except this particular run looked like it was turbo hyb(r)id Civic vs Y2K M5 vs Supra.
Either way, he wasnt on the stock twins.
Video will be up hopefully later today
Most Supra big single turbo cars(T60-88) w/o upgraded fuel system are at around 500 at the wheels......Since you're a F-body driver, I can't call bs......but it is sketchy. If you car only trapped 114 1/4, that puts you around......350ish hp. Are you spraying in the vid?? A car with 350rwhp and a little spray, I'd fully believe you.
Either:
A) You're spraying and don't want anyone else to know
B) That supra has some SERIOUS tuning issues
So,
I got to go with B. I believe you as you've been pretty straight up, and you're car doesn't act like a Sprayed car. Also, Supra's are notorious for being very finicky. Either way, the video doesn't lie.
Good Kill!!
Tim
neither do videos, though. nice kill venkman
