Mach at the track
Nice runs Stoppy! Get those other mods on and lets see what it runs.
Great driving, btw...
Wish I had your driver mod...I am still missing that..LOL
BTW...finally got the clutch, aluminum flywheel and new throwout bearing. It is all going on next Wed...I am going with the SPEC on both items...
I will let you know how it turns out...
PM me what setup you went with please.
#34
This^^ I've ridden in quite a few mach 1's with gears and not. I'm always impressed with how well they pull down low its just after the get up around the top of 2nd or third they run out of breath compared to an ls1... Before I had my car my buddies light bolt on z28 would get pulled about a half of car to 45 with my other friends light modded mach 1... after 2nd gear though it was all over lol
Good runs stoppy! Go to a 1/4 track and see what she does for real. I've always liked machs for the shaker setup
#37
LOl.....the funny part is you talk about your "set-up" being so great but did'nt run the nitto's. Notch's car went faster than yours just did in the 1/8 on wore out nitto's. I guess the camaro chassis is just that much more superior......on Notch's set-up with wore out stock suspension just "works" better....lmao
uh ho red you did it now.
#40
This^^ I've ridden in quite a few mach 1's with gears and not. I'm always impressed with how well they pull down low its just after the get up around the top of 2nd or third they run out of breath compared to an ls1... But then they get to 88mph and the flux capacitor overdrive worm hole thingy kicks in and they teleport to 200mph... I seen it done.
Before I had my car my buddies light bolt on z28 would get pulled about a half of car to 45 with my other friends light modded mach 1... after 2nd gear though it was all over lol; for the ls1, because the aforementioned happened at 88 mph...
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
In all seriousness car looks good lol
