Best wheelie in the street
205 heads
super victor intake
Teds carb shop 750 hp
T5 trans
28-10.5 slicks
Car is ridiculously impressive.
Like you see in the video, no.
There is a certain way pimp juice, VHT, etc etc need to be applied to get the correct response from them.
Sprayers, Burnout... Then sprayers with a rolling burn out (spray the entire time)... Back up sprayers another rolling burn out (sprayers still going.) After this try to kill a minute or two before launching if possible. Say you need to check tire pressure or some BS and use as much time up as possible.
The hotter you get it, the better it works... Obviously you can't torch it since you are trying to be discrete.... But that is the reason for the rolling burn out.
Then back up and launch where you have sprayed/burned out.
That would be the best method without being noticeable.
Spraying it, burn out, launching... That isn't going to yield too great of results. You would see an increase of traction but I'm not sure it would be worth your money.
Most people won't bitch if you start pouring orange soda down.. It isn't going to help nearly as much as VHT/juice but it will help.
If they think it isn't orange soda, drink some.
Work? Yes.
That is like saying they wouldn't run any faster at the track VS the street.
Obviously they still would have got beat... Like you said, the Mustang is set up very good.
They didn't do any prep for the Mustang/GTR race... Look how much softer the Mustang left, the prep matters.
Of course it would have made a difference.
you are right about me not "street racing enough" to me its a bunch of talk and arguing for hrs before anyone even runs..id rather be doing something or drinking beer.
and of course prep makes a difference...its pretty obvious what i was getting at...the mustand was gonna win regardless.
I see factory panels and seat in the video.. But it probably still only weighs 3K, possibly less being a Fox.
It freight trained a car that its VERY base model you can buy makes 500HP and does 0-60 in 3.2 seconds. This is an upgraded model that is modded. Mid 11s @ 120 are magazine stock times.
Let that sink in a little.
