Street Racing & Kill Stories Basic Technical Questions & Advice
LT1 Z28 vs. S197 GT 3v
Old 04-05-2016, 07:21 PM
  #381
Nick.H's Avatar
My buddies LT1 doesn't leak oil but he had to rebuild both the top end and the transmission before 150k miles. The dude he bought it from was shady though.
Old 04-05-2016, 07:36 PM
  #382
408-99-f's Avatar
I put a rear main seal in my 1994 formula at 157k, that was the only major oil leak it had in the 10 years I had it. It was a little damp on the front crank seal, so I put a speedy sleeve and new seal in that at the same time. Was good to go. I thrashed the pissed out of it too. Have had friends have them with no major oil leaks. I did a watter pump drive seal in one the other day at work, but it was nothing major had the watter pump off and it was damp. Some people just have bad luck I guess.
Old 04-05-2016, 07:48 PM
  #383
Nick.H's Avatar
Yeah seems like they can be hit and miss
Old 04-05-2016, 08:34 PM
  #384
JC316's Avatar
Originally Posted by ThoR294
IDK if you knew but a lot of cars run on oil. They usually have gaskets and sealant. Just a pro tip, gaskets and sealant overtime tend to wear out, and tend to *gasp* spring a leak. .
I'd rather have a small oil leak than a coolant leak. Sure some people have gotten intake gasket leaks. Maybe because when the PCV gets clogged, you know, the crank case needs to breathe, and the weakest link is that intake spot? It could have maybe been the VC gasket, or the oil pan gasket? hmmmm.
LT1s get a bad rap because of ******* morons like you. "Optis are bad because I keep throwing $60 autozone optisparks at it" The water pump placement sucked, but unless it exploded and you ignored it, the opti survived.
zzzzzzzzzzzzzzzzzzzz
Wait, motors run on oil? Gaskets and sealant aren't supposed to wear out, the fact that the LT1's do is what makes it a leaky motor. I've had the leaky intake without PCV failure, but even if that is the reason, you don't see other motors spewing oil. It's a poor design by GM.
You don't see me making excuses for the Duratec 3.0L because the cat converters break down and suck the material back up through the EGR. It's just a bad design.
FYI, the duralast gold optispark is actually a damned good unit. The LT1 doesn't get a bad rep off from morons, it gets a bad rep because it's a bad motor. It's why the LT1 fbodies are dirt cheap, despite the fact that the LS1 cars are uglier.
Old 04-05-2016, 08:47 PM
  #385
***Repost Police***
Irunelevens's Avatar
Originally Posted by HioSSilver
From the looks of it a pi2v and old lt are about .3 apart .....just like i said. That don't mean a lt will outrun every 2v.......but it probably should.
So you're using only the LT1 SS times then? Don't want to talk about the other couple hundred-thousand LT1 F-bodies?
Originally Posted by JC316
God no. Aside from a couple of hero runs, a stock 2v MIGHT see a 13.8, just saying that an LT1 is in the exact same boat. Drop a 3V into a 99-04 GT and I bet it sniffs around 12's, but not in the 3600lbs S197. Mid-low 13's is about the limit.
You clearly don't know 2V engines. PI 2V makes peak power right at 5K rpm, 4.56 is way too much gear for it. 4.10 is about the sweet spot for a 5 speed PI GT.
Yes to all of the above.
Old 04-05-2016, 09:55 PM
  #386
ThoR294's Avatar
So then why does anyone replace gaskets if they don't wear out? You seem to be the only one on this thread with an LT1 that pissed oil even after a rebuild
Duralast gold was a good unit because it was a rebuilt delco for a while, not sure now if it is though.
LS1 cars are uglier? Only one that is "uglier" is the catfish.
Old 04-05-2016, 09:57 PM
  #387
***Repost Police***
LT1 WS6 > any other 4th gen, in the looks department.
Old 04-05-2016, 10:13 PM
  #388
JC316's Avatar
Typically a gasket goes bad when the bolts holding it down loosen up and it starts leaking. Otherwise gaskets only need replacing if they were damaged during disassembly. I will typically replace them, just for cheap insurance, but I have been in a pinch before and reused oil pan, valve cover, and timing cover gaskets. Never have a problem.
The install of the rear main on that car was fine, doesn't rule out a potentially bad gasket, or something wrong with the sealing surface on the crank. It was a new crank, so it might have been machined funny.
That corvette was leaking out the intake as well, that stopped with the rebuild. An LS1 firehawk and WS6 look better than the LT1 body, but the rest are LT1 all the way.
Old 04-05-2016, 11:40 PM
  #389
big hammer's Avatar
I most often see SBC's leak because of over torque on the cheap tin covers or when people don't use the correct washers or "load spreaders".
Then the tin just bends and won't seal properly
Old 04-06-2016, 06:25 AM
  #390
408-99-f's Avatar
That, and you see people still cheeping out on gaskets and using a cork gasket lol. It's all pushed out lol
Old 04-06-2016, 08:25 AM
  #391
HioSSilver's Avatar
God i hated cork gaskests. I did cart wheels when fel pro came out with a one piece rubber oil pan gasket for the sbc.
Old 04-06-2016, 08:56 AM
  #392
408-99-f's Avatar
Yup, with the 4 plastic dowels that screw into the bolt holes that hold the gasket so you can slide the pan over them and everything is lined up. Alot easier
Old 04-06-2016, 09:52 AM
  #393
Click Click Boom's Avatar
My 2v smokes bolt on LT1's and bolt on LS1's left and right. From digs and rolls
Old 04-06-2016, 10:04 AM
  #394
Puck's Avatar
Old 04-06-2016, 10:20 AM
  #395
MaxxRPM's Avatar
Old 04-06-2016, 10:22 AM
  #396
ThoR294's Avatar
Old 04-06-2016, 10:49 AM
  #397
NateLS1Mustang's Avatar
Old 04-06-2016, 12:44 PM
  #398
big hammer's Avatar
I believe it
Old 04-06-2016, 01:08 PM
  #399
Nick.H's Avatar
Jakes back
Old 04-06-2016, 06:14 PM
  #400
Birdracing's Avatar
I can not see how people say that the LT1 motor is a bad motor. I can't wait to get the heads and cam on mine, surprise people.
Quick Reply: LT1 Z28 vs. S197 GT 3v
