Street Racing & Kill Stories Basic Technical Questions & Advice
bolt on ls1 vs bolt on 5.0
Old 03-30-2014, 10:37 AM
  #81
R6cowboy's Avatar
Originally Posted by Gt4urass
Lol, same tactics I see. You don't make me mad honey, you make me laugh.
He's the only one that doesn't realize he's the village idiot around these parts.
Titan, we're all still waiting to see that 408 T/A of yours in action. Come on bruh, lets see it!
Old 03-30-2014, 10:41 AM
  #82
ohioborn80's Avatar
Originally Posted by HioSSilver
I've never heard of a legitimate stock block coyote making 2000hp. From what I have seen posted you better not go over 800 if you want it to live any time at all. Sleeved blocks are not a REAL example of any engine......that would be a modified block and no real indication of what the stock block can do.
I
Not like it matters.......who the **** cares what about a 2000 hp engine? None of us are running one. Most of us are just ******* with bolt-ons or h/c or cam only shitty.
To see the real potential of the engine it HAS to breath on it's own anyway. Anything other than that is just sizing the boostinator/ fuel system to the power you want. I give the guys that build it the credit for that.
The block on a 5.0 is good to about 1000whp. The internals on a coyote are good to about 650-700whp on 93. Add e85 they have been pushed to 800whp. A boss engine will handle more just of the better internals. And few have been pushed to 1000whp on stock long blocks.
Old 03-30-2014, 12:08 PM
  #83
big hammer's Avatar
Originally Posted by MACHXLR8
I thought we already established from a previous thread that the Camaro in the vid also has an aftermarket converter. Am I mistaken? It seems that this mod always gets missed in the list of "things" done. With that one modification alone, that will give a big advantage to the Camaro at the track coming off the line...(as shown in the vid)
I am not pulling for the 5.0 since I like both cars, but for the A4 Camaro to be running 12.4 at 113mpg with basic bolt-ons, there is more going on with that car IMO. If you want to use the words such as "comparable modifications" when talking about these two cars, then have the 5.Bro install a converter also and run them again.
If I am wrong about any of my assumptions (converter), than I apologize.
the Camaro does seem to come out hard.
Old 03-30-2014, 12:14 PM
  #84
snake95's Avatar
More LS1 guys getting put in their place, nothing to see here
Old 03-30-2014, 12:15 PM
  #85
big hammer's Avatar
ummm... wut?
Old 03-30-2014, 12:23 PM
  #86
98CayenneT/A's Avatar
All I know is if I were lined up against one at a light on the street I would not be afraid to open up my wallet if the 5.0 wanted to do a couple stop light to stop light runs
Old 03-30-2014, 12:41 PM
  #87
HioSSilver's Avatar
Originally Posted by big hammer
ummm... wut?
LOL.......coming from a guy who will get mopped by proper bolt-on ls1 that really don't mean much does it Hammer?
Old 03-30-2014, 12:42 PM
  #88
big hammer's Avatar
not really. isn't he H\C\I as well?
Old 03-30-2014, 01:12 PM
  #89
S8ER95Z's Avatar
I've asked this question before and can never get a answer. What do yo guys think the hp spread on a modern type stock fuel injected engine should be?
Assuming all are in proper running order with similar options. I would think 1% difference in hp/tq would be alot on identical cars.
I would guess around 10-15rwhp.... If you are looking at a specific year the difference should be minimal... In this case I was thinking year to year (for example in the ls1 case it's not unheard of for an 01/02 to make a bit more power than a 98 car). When I mention a strong car though I'm not merely talking about rwhp. Gearing, transmission type, weight and tires can make a big difference even of the two cars are packing the same exact amount of power. When the right combo comes from the factory you start hearing people call it a freak when it's really just a great example of how the car should be performing.
Old 03-30-2014, 01:17 PM
  #90
snake95's Avatar
Car's at the tuner now, gotta fix my power steering line then it can be tuned.
It won't run 14s with h/c/I, I'll tell you that
Old 03-30-2014, 01:20 PM
  #91
evangto87's Avatar
One thing you guys have to udnerstand is there were ALOT of changes made to the LS1 through its years. All of which were a wash. No more then a 10hp spread (longblocks themselves... not different intakes, exhausts from factory). For example... look at the cam differences between a 98 and an 02. As far as comparing 241s to 853s... you are grasping at straws to say that the 241s flow better. You are talking such minimal cfm difference that the amount of oil in the runners have a bigger effect on the HP. The ACTUAL reasoning behind changing the top end was to duplicate the same top end power while making a bit more low end tq...which is why there is less cam and more cylinder head/intake in the later model ls1s. And to be quite honest... the FASTEST ls1 f bodies ive ever encountered/driven... were all 98-99s. Does that mean they are the superior motor... no. Just means the cleaner running motor with better ring seal was the stronger motor. Thats how little the changes effected everything. 2000 ls1s on the other hand were the transition year. There were all sorts of factory part combos in random motors produced through the year.
Old 03-30-2014, 01:23 PM
  #92
wbt
wbt's Avatar
Originally Posted by islander033
According to SRK, it's crazy easy to do.
They just don't feel like doing it because they have other immediate goals.
According to this list...
https://ls1tech.com/forums/drag-raci...1-74-bump.html
...there have been a total of 3. Gutted, non-street legal cars. My car has 500+ lbs. on those and I can drive down the freeway at 80 still getting 25mpg with the A/C blowing cold. The hard life of running a 3.31 rear gear.
Also, the top car there ran that time in -1K' DA, not +1,700' DA like the poor guy running his 5.0.
Here is the most complete bolt-on 5.0 list:
http://www.modularfords.com/threads/...Racing-ET-List
Old 03-30-2014, 01:31 PM
  #93
7 Second Club
islander033's Avatar
Your lists, logic and common sense have no place in the world of SRK.
So you better GTFO!
Old 03-30-2014, 01:45 PM
  #94
big hammer's Avatar
I would hope not!!
Old 03-30-2014, 01:47 PM
  #95
R6cowboy's Avatar
What's snake's h/c/i and drivetrain setup?
Old 03-30-2014, 02:34 PM
  #96
Blown383LS1's Avatar
He can't even post a pic, much less a vid of it in action. He has been asked repeatedly by Cwarta to meet up locally and goes MIA every time, lol.
Old 03-30-2014, 02:36 PM
  #97
big hammer's Avatar
camel humps with a 3\4 race cam, eldebrock high rise intake and an m22 rockcrusher with 3.73 posi track rear end with 50's on it.
Old 03-30-2014, 02:54 PM
  #98
Only 3 mods on that car:
Lid
Tune
3.73's
That equals 12.4 @ 113 in a stock stall A4. Happens all the time.
Old 03-30-2014, 02:56 PM
  #99
S8ER95Z's Avatar
I'm not sure who your post was for... As stated 10-15rwhp difference... With the larger spread being a4 vs m6.
Old 03-30-2014, 02:59 PM
  #100
4PointSlow's Avatar
The car in the video does not have an aftermarket stall. That's what was confirmed in the other thread. I ordered a circle d 4c+ 3800-4000 single disc stall from Brian @ KYTP performance which is not in the car yet, I'm not putting a big stall in a stock 60e.
Quick Reply: bolt on ls1 vs bolt on 5.0
