Street Racing & Kill Stories Basic Technical Questions & Advice
Going up in flames
Old May 20, 2004 | 10:41 PM
skeetersws6's Avatar
Default Going up in flames
since i own a A4 tranny, if im at a dig and i have it in D, should i hold my brake and hold my RPM's or should i just punch it? i need this info when i go to race.
Old May 20, 2004 | 10:42 PM
and if i am to hold my RPM's , what should i hold them 2?
Old May 21, 2004 | 08:33 AM
99-LS1-SS's Avatar
STF Veteran
I'm not sure on a stock converter. With my converter I just punch it and my converter flashes. It might be better for you to stall it up to around 1500 to 2000 rpm's and then lauch. That should help you get into your torque range a little quicker.
Old May 21, 2004 | 12:00 PM
StangManWithLS1Dreams's Avatar
owning an A4 myself and raceing for some time it really depends you wanna find the rpm that will allow you a good jump but wont hurt your tranny.....if it where me in an ls1 i just wouldnt do it...just romp on the gas let off a bit to catch and get back on it... save the tranny a bit of life
Old May 21, 2004 | 12:42 PM
jimmyblue's Avatar
Moderator
A little foot stall will load up the suspension and
lessen some jerk responses that make you lose
traction & hop. But you should practice ahead of
time and learn the smooth limit to non-tire-spin
launch as this gets you the best result with a
Torsen (once the tire lifts, traction drops big time).
Burnouts look impressive but quiet authority wins.
Old May 21, 2004 | 01:55 PM
PSU_Engineer's Avatar
99, Remember what happened to me...
Only flashed it to 1100 then...
OOOOps Smoke show!
Good thing the other car was only a Taurus SHO
Old May 21, 2004 | 05:02 PM
AK's WS6's Avatar
At the track when I know i'm gonna hook hard I load the drivetrain just a little, but only to take the inital force off the drivetrain, not for a racing advantage.On the street I just punch it and then feather it a little to keep it off the rev-limiter if i'm spinning bad.
Old May 25, 2004 | 01:25 AM
BriancWS6's Avatar
Well at the track I load it up to around 1300-1400 rpm and nail it when the light turns. That is as high as I can load it up before the brakes won't hold any longer. That is on the stock stall and street radials. Times with that method in sig. Good luck!
Old May 25, 2004 | 01:31 AM
| Powered by Satan |'s Avatar
yeah, just hold it around 1400 or so w/ a stock tc... you should be fine
