15 GT doing work as usual
I agree that it's a no brainer but my point had nothing to do with which engine is better. Keep in mind that I said usable power. For all I know the Coyote makes more power under the curve from 6000-8800 than the LS7 from 5000-7200 (most likely RPM ranges they'd be in while drag racing, depending on gearing). My point was simply that it seems like he's misrepresenting the power those engines are making in the midrange as being equivalent.
I laugh when people down play e85 as a "do nothing 10hp" mod. It gains a lot on any engine just not at peak but for some reason 5.0 guys near me love to play it off as though they did it for the cheaper fuel price
.http://www.svtperformance.com/forums...mparison-today
E85 isnt really about peak gains on ANY NA engine its about what comes in the midrange and before redline. For that it provides solid gains, every time the car shifts you're dropping into a much higher powerband.
If I move back down to soflo in a year or so i will def switch to e85. but now up in cocoa the closest station is 20 miles away whereas in soflo it was 5 min in either direction
Honeslty, unsure why anyone would want to go E85 NA unless they want a max effort NA setup and want to run some extra timing. Only way I would go E85 is FI. I am trying to look into a flex fuel setup for my build. E85 is not plentiful in my area, so I want to be able to throw 93 octane in and roll as needed.
Ya if I can get a dual map pcm and a sensor I'd do the same thing. It really is for people trying to squeeze all they can from their setup. But like stated e85 might only show 10 at peak but usually 15-20 in the midrange. Lots of people like to forget to admit that part....That goes for any engine though not just a 5.0.
Saying e85 gains 10whp and doesnt do much of anything is like saying a boss intake is a waste of time because it loses low end tq and makes 5whp more at the factory redline.
