Street Racing & Kill Stories Basic Technical Questions & Advice
FBO 16 mustang vs bolt on ls3 fat gen
Old 06-27-2016, 12:32 PM
  #201
JC316's Avatar
Originally Posted by HioSSilver
I know what you said and know you have yet to back up anything you've said. No go on.....you are useless on a car sight.
If you're so sure, prove it.
Old 06-27-2016, 01:03 PM
  #202
Mike Morris's Avatar
Phil heads are not ported. Nor are Hios
Old 06-27-2016, 06:13 PM
  #203
ZNix's Avatar
Phil has a lot more than just exhaust and tune.. Lets get that straight LOL.
Old 06-27-2016, 10:34 PM
  #204
Poppacapp's Avatar
Where di uou come up with this ****?
I know what you said and know you have yet to back up anything you've said. No go on.....you are useless on a car sight. You would have great succes on a gay **** sight tho.
Poppa makin **** up cause he skurred to get drug
Poppa not skurred. Poppa not worried, although it would be a good race, with me a car or two ahead. But the fact is, that Phil's car has more mods(that contribute to the speed of the car) than I do. So as usual... takes more mods on a 5th gen to run with a 5.0. I am not hating on the 5th gen by saying that... Phil's car is sweet as hell. But its just how it is, and how it has been.
And I "came up with that ****" because a 5th gen will not trap 117 as yall claim it can with just exhaust, and no tune.. sorry. Not happening. The GMPP CNC LS3s would be stealthy as hell... would not be able to tell..... LS9 cam would be stealthy as hell... no lope at all... So that is what I would do to the car. BUT.. the difference between me and you, is I would divulge those mods... you on the other hand... would not.
Old 06-27-2016, 10:36 PM
  #205
Poppacapp's Avatar
^^this. Sorry... but no exhaust only 5th gen is going to run with my car in track mode.... no way in hell... only Shadymods would get it in the ballpark.
Old 06-27-2016, 11:41 PM
  #206
big hammer's Avatar
I'm not sure about that. They're a drivers race stock and none of your mods made a difference
Old 06-28-2016, 12:13 AM
  #207
Poppacapp's Avatar
You have a point man... the no difference mods make a difference differently
Old 06-28-2016, 05:27 AM
  #208
HioSSilver's Avatar
You prove you're a know nothing with every post
This....thanks mm
Well if you start there you're doin it wrong.
You wanted mod for mod. I would have to assume you have picked your best mods......phil picked his.
It's pure ******* stupid for anyone to want to mod 2 different cars from 2 different makes the same.
Lolz
Old 06-28-2016, 09:40 AM
  #209
ZNix's Avatar
Care to list out the mods? Might help if you put them in bullet form...
Old 06-28-2016, 10:59 AM
  #210
Poppacapp's Avatar
Oh, I know 100% that rotating mass is the first place you start on the 5th gen. Driveshaft, lighter wheels, much lighter clutch/flywheel. Tried telling my buddy more than once. He loved the heavy GM wheels though.
I definitely didnt pick my BEST mods man lol.. If I did that, I would have put a stall in first thing, along with a CF driveshaft, and aeroforce brakes. Long tube headers/no cats would have been on that list too. Bottom line is, in my current state, .... catback/tune.. there is no way in hell a 5th gen will keep up with those mods. It will take MORE mods on the 5th gen to keep up... it has always been that way.
Again Hio.... I am not putting Phil's car down. And yes, I am sure you know your stuff on mods. But you can't sit here and say that if we had the same mods, the 5th gen would be faster. It just won't happen. Power to weight is king... and the 5th gen is just too much heavier than the 5.0.
Maybe. But Bolt on is Bolt on.. and FBO is FBO... those mods across all brands pretty much follow the same line. Sure.. you can to EXTRA stuff on top of the bolt ons... weight etc... but Bolt on is a bolt on is a bolt on
Old 06-28-2016, 11:02 AM
  #211
NateLS1Mustang's Avatar
This....thanks mm
Lolz
That's weird because you bitch and throw a hissy fit every single time a GM car is compared to any other manufacturer vehicle with different mods on it..
Old 06-28-2016, 11:27 AM
  #212
Poppacapp's Avatar
I will start.. here are all mods currently(as in right now) on my car that are not as factory delivered:
Front wheels: 19x9.5 SVE Drifts with 275/35-19 Nitto Invos
Sitting in building: 17x4.5 Racestar 94 Series Darks with 26x6" Mickey Thompson SR Radials
Rear wheels: 17x9.5 Racestar 94 Series Darks with 295/45-17 Micky Thompson ET Street Radial IIs
Sitting in building 19x9.5 SVE Drifts with 275/35-19 Nitto Invos
nGauge Tuner : suction cup mounted to upper left windshield to use as gauge for Lambda1/2, knockr, total spark, Ethanol%, and Flex fuel learn flag(0 or 1 for learned)
Lund Racing Flex fuel tune with 93octane fuel in the tank... when I want to run E85, I simply leave the house with 60miles to empty, and drive an hour to my E85 spot, and fill the tank up with E85 for 1.79/gallon at the same pump I can get 93 from.
Stainless Works h-pipe catback(car has cats and oem manifolds) - Bought only for sound. No performance gained, and honestly I might have lost some low/mid torque from the 3" piping over oem
Steeda Cold Air Intake: Installed Saturday... have tune revision.. needs more testing... may take it off because I do not like the increase in IATs. Most likely will go back to my tried and true stock airbox setup.
Reische 170 degree thermostat
UPR Oil Catchcan on passenger side
BMR Drag (LOWERING DUGGY!)Springs: Have not helped the 60fts as of yet...and frankly I got them to make the car look better... should help when I upgrade more power, and add the Viking rear shocks
BMR Vertical Links - Help with wheelhop
BMR CB005 Cradle Lockout kit - Help with wheelhop
Both of the above were done to prevent wheelhop. They have worked as intended and I get ZERO wheelhop even while spinning on street tires.
Diode Dynamics front LED switchback bulbs and marker bulbsYellow lights are ugly.. I wanted white LED)
Mirrortap power cord for Valentine 1 detector to tap power at mirror
Blendmount mirror mount to mount Valentine 1 detector under rearview mirror
Roush Rear Spoiler
Black 5.0 badges on fenders
So.. here is a list of EVERY piece on my car that is not as delivered from the factory. EVERYTHING. I have performed NO additional weight reduction to the car. Full interior as delivered from the factory.
Now lets see Hio crew count every one of these as "mods" lol. My Br0 is now a 13 mod bro!
This is a simple combo that has taken me to 11.81 ET and 117.4 traps
Hiocrew is deathly scared of me adding the following and going true FBO:
Long Tube Headers(Like Phil has)
Cat Deletes(Like Phil)
Intake manifold(CJ/Boss/GT350)
Larger throttle body
Carbon Fiber driveshaft
Stall converter( If Phil can add a 5lb clutch/flywheel, I can add a stall, right?)
With all mods above, Phil's 5th gen would need a Heads/Cam/Nitrous setup to keep up with my basic FBO 5.0.
So... now... Hiocrew.... list your mods... You see mine... its not like you boys are grudge racers... no need for secrets... right? I have laid mine completly on the table here.
You turn
Old 06-28-2016, 11:28 AM
  #213
Poppacapp's Avatar
Oh ****!!! sorry!! I forgot to list window tint!!!!!!
Old 06-28-2016, 11:30 AM
  #214
Lawhead's Avatar
This forum won't have enough capability to hold all of Doug's mods lol and good luck having him disclose them LOL
Old 06-28-2016, 11:33 AM
  #215
Poppacapp's Avatar
True that. I mainly mean Phil's car. But I never understood the need for such secrecy on Dougs mods... he does not grudge race. We kind of know why he doesnt divulge them though... because if he DOES... then we will be able to say "No damned wonder your car runs what it does... nothing special".
Old 06-28-2016, 11:44 AM
  #216
HioSSilver's Avatar
All in red........but you missed some
And you're foolin yourself.
Proof? While you're at post up your car
Roush Rear Spoiler
You turn
Lol.......phils not gonna do race brakes, drag pak. Why dumb a car like that down?
Do it man.....it's gonna take more mods for ya.
Well not every one is as good as you at buying hotrods slowing them down and parting them out.
Btw....all my mods used to be in my sig. You used to recite them like a was your Jesus
Old 06-28-2016, 11:46 AM
  #217
Lawhead's Avatar
LMAO at all your mods in your Sig
we know you're a liar but come on Dougy!!!
Old 06-28-2016, 11:47 AM
  #218
7 Second Club
islander033's Avatar
When will Hio ever tire of looking the fool?
Old 06-28-2016, 12:21 PM
  #219
marc97taws6's Avatar
5Gs are poop
Old 06-28-2016, 12:55 PM
  #220
Nick.H's Avatar
I remember said sig.... It said "bolt on LS6 faceplated t56" there ya go. All mods listed
Quick Reply: FBO 16 mustang vs bolt on ls3 fat gen
