Street Racing & Kill Stories Basic Technical Questions & Advice
The real deal, LS3 vs COYOTE
Old 07-14-2016, 08:02 PM
  #261
08ls3's Avatar
Originally Posted by marc97taws6
730rwhp 3200lb car only runs 10's?
Maybe you didn't listen to what the owner had to say..car would run well into the 9's with a bigger stall and exhaust..only thing this car has is a supercharger, 2800 stall and a cam designed for na..nothing else has been touched..
Old 07-14-2016, 08:09 PM
  #262
ZNix's Avatar
So it would need more mods to run 9s.. Damn, never would have thunk it...
730rwhp is 730... rwhp...
Old 07-14-2016, 08:11 PM
  #263
08ls3's Avatar
Can your car run a 10.08 at 138mph?
Old 07-14-2016, 09:05 PM
  #264
HioSSilver's Avatar
Originally Posted by Z06PSI
It will. The back to back comparison between a 6th Gen Mustang and a 6th Gen Camaro is pretty telling. I am at around 10psi and making 700 rwhp 590 rwtq and the Camaro guys are struggling to get to 600 rwhp but making 600 rwtq.
Stock motors on both.
From what I've read the di is holding them back a little right now. Can't get enough fuel to them.
Old 07-14-2016, 09:33 PM
  #265
ZNix's Avatar
It probably can, yea.
Probably do it with about 650 or so to the ground.
Old 07-14-2016, 10:32 PM
  #266
Poppacapp's Avatar
Originally Posted by big hammer
5.0 struggles to make as much hp as 4.8's
GM performance cars struggle to perform with the engine that came from the factory in them. Must use junkyard truck motors to go teh fastez..
Old 07-14-2016, 10:35 PM
  #267
Poppacapp's Avatar
here is a stock block,head ls3 a6 vette making 730whp on 12lbs..would make way more with a cam designed for boost...
10 Second C6 Vette - Daily Driver - YouTube
Originally Posted by 99peweterls1
Shelby Gt350 with a whipple first with stock exhaust and then kooks headers
Yep.. 2015+ 5.0s make similar to more horsepower on 12lbs with the twin kits than the GT350 example. They are handling 15psi range too.
5.0s are highly regarded boost motors
Old 07-14-2016, 10:36 PM
  #268
Poppacapp's Avatar
And that is going to be a common problem with DI setups. Ford will have the same issue when they go DI unless they introduce supplemental injector setups from OEM.
Old 07-15-2016, 07:45 AM
  #269
HioSSilver's Avatar
I've mentioned that also. Furd has some dual injector set ups already. It's gonna take that for tunability i think.
Old 07-15-2016, 08:12 AM
  #270
big hammer's Avatar
I think Holley has developed a supplemental fuel injection intake for the lt1
Old 07-15-2016, 05:13 PM
  #271
99peweterls1's Avatar
The turbo setups be a wee bit more efficient lb for lb. The coyotes are definitely holding some impressive power figures. Still 840rwhp of blower car that revs to 8k. I'd be smiling from ear to ear.
Old 07-15-2016, 09:08 PM
  #272
Poppacapp's Avatar
Yeah, but I think there is a reason why we haven't heard much else out of them about the car. The Voodoo is not meant for boost. I have no idea what Lethal was thinking. But its definitely something different.
Old 07-16-2016, 08:39 AM
  #273
redbird555's Avatar
Comparing boost from turbo's to blowers is not accurate at all. Twins will always make more power 10-12 psi is mid-high 600's on a coyote with a D1. The two motors make very similar power on boost with equal mods.
Old 07-16-2016, 09:17 AM
  #274
big hammer's Avatar
Lethal sucks. I think everyone was looking forward to an NA build with the gt350. But they just went to their old fail safe of "just throw a blower on it".
Old 07-17-2016, 03:15 PM
  #275
Mike Morris's Avatar
Is new bro bascially same bottom end? I have seen some sick new bros with fi and stock bottom end with autos down here
Old 07-17-2016, 06:50 PM
  #276
marc97taws6's Avatar
2015+ models come with much better rods, the weak links of the 11-14
Old 07-17-2016, 07:46 PM
  #277
HioSSilver's Avatar
I thought the major bottom end upgrade was firged pistons on the s550 5br0s
Old 07-17-2016, 09:28 PM
  #278
Poppacapp's Avatar
Forged Rods on bottom end. Heads flow more, intake flows pretty close to what the Boss intake flows with the exception of power past 7000rpm. It's fairly close to a Boss motor when it's all said and done.
Old 07-17-2016, 10:14 PM
  #279
assasinator's Avatar
So I stick a set of stock 2015 heads on my coyote its still bolt on eh?
Old 07-17-2016, 10:31 PM
  #280
NateLS1Mustang's Avatar
Hio says that's still a bolt on for sure.
Quick Reply: The real deal, LS3 vs COYOTE
