Bolt on Mach 1 destroys bolt on LS1 Z28
#361
#363
#368
If it touches the oil, it isn't a bolt on. It's pretty widely accepted that if you are opening up the motor for upgrades, you're past the bolt on stage. Don't really need to read the pointless arguing and **** here that is just regurgitating what you tards have argued about for years.
#369
Why should what year we are in affect rockers
Think about it.
Troof
Russians hacked that ****.
Now just feelz hurt and crying
#370
#379
Wow. I figure rockers as a bolt on & don't give a half a **** what someone else says. Who really cares? I saw a 5.0 at the track once idling with a lump. I asked if he had cams. "Nope thats just from the tune". If you can change your valve events electronically you must feel pretty special. Great. Where are the valves/cams/electric ****? Inside the motor. Changing their operation from stock...no bolt on right? Seriously, who ******* cares. Just swapping to a bigger ratio roller rocker may give you 10hp if your lucky. Changing all that valve **** in the ford probably gives you something too.
Carry on.
Carry on.
