Street Racing & Kill Stories Basic Technical Questions & Advice
Bolt on Mach 1 destroys bolt on LS1 Z28
Old 12-19-2016, 11:52 AM
  #381
sw07gt's Avatar
So about that bolt on list you don't qualify for.....
Old 12-19-2016, 12:02 PM
  #382
big hammer's Avatar
Originally Posted by sw07gt
Aren't they still inside the long block?
I see you digress
Old 12-19-2016, 12:04 PM
  #383
big hammer's Avatar
Originally Posted by SoFla01SSLookinstok
Wow. I figure rockers as a bolt on & don't give a half a **** what someone else says. Who really cares? I saw a 5.0 at the track once idling with a lump. I asked if he had cams. "Nope thats just from the tune". If you can change your valve events electronically you must feel pretty special. Great. Where are the valves/cams/electric ****? Inside the motor. Changing their operation from stock...no bolt on right? Seriously, who ******* cares. Just swapping to a bigger ratio roller rocker may give you 10hp if your lucky. Changing all that valve **** in the ford probably gives you something too.
Carry on.
Agreed. I don't really understand the butthurt
Old 12-19-2016, 12:33 PM
  #384
assasinator's Avatar
Originally Posted by Guitar
If it touches the oil, it isn't a bolt on. It's pretty widely accepted that if you are opening up the motor for upgrades, you're past the bolt on stage. Don't really need to read the pointless arguing and **** here that is just regurgitating what you tards have argued about for years.
my intake cams are bolt ons.
i only take the valve cover off for them. no timing cover, no damper, no springs, no rockers, nothing, just valve covers and a few bolts per side. they touch oil. bolt on. i'm good.
exhaust cams weren't a bolt on. they required removing the front cover. intake cams are bolt ons by your definition Hammer.
Old 12-19-2016, 01:03 PM
  #385
7 Second Club
islander033's Avatar
Oh snap!
Old 12-19-2016, 01:10 PM
  #386
JC316's Avatar
Originally Posted by HioSSilver
So then adjusting cam timing would be out the door to.
Depends on how it's done I would say. If you're opening the motor, adding an adjustable cam gear, degreeing the cam and reassembling, then I would say that's definitely out.
If it's done via a tune, I would say not. That is taking advantage of better technology. It's like saying you should be able to use trick flow heads on a 4.6L and call it stock, because the LS1 flows better stock.
Old 12-19-2016, 01:23 PM
  #387
scotty2000ss's Avatar
Can't believe DD crew is still crying about this. Give it up lol
Old 12-19-2016, 01:26 PM
  #388
7 Second Club
Did you do rockers and springs on your build?
Old 12-19-2016, 01:27 PM
  #389
sw07gt's Avatar
Old 12-19-2016, 01:31 PM
  #390
  #391
Not yet.
Old 12-19-2016, 01:42 PM
  #392
Nick.H's Avatar
It gave me 4hp.
Peak hp. But how much was it good for under the curve? I'm curious because we are doing 1.7 RR's on my buddies LT1
Old 12-19-2016, 02:25 PM
  #393
7 Second Club
Not yet.
When are you doing them? Your sig says all the bolt on man.....
Old 12-19-2016, 02:31 PM
  #394
HioSSilver's Avatar
Lol.....sw was had.
Yea nick it does a little better under the curve. Probably does even better on a lt1.
You know what puts iron in ironic here??
Sw the badass no rules grudge racer tryin to figure out the rules for bolt ons. Only a democrat coukd be so mislead.
Old 12-19-2016, 02:36 PM
  #395
big hammer's Avatar
Ok so your bolt on max effort coyotah still made less power than me!
Old 12-19-2016, 03:21 PM
  #396
When I get around to it.
Old 12-19-2016, 03:45 PM
  #397
7 Second Club
Is that before or after you try and get your car on the bolt on list?
Old 12-19-2016, 03:47 PM
  #398
sw07gt's Avatar
Lol.....sw was had.
I don't make the rules doug, I'm simply repeating them.
Old 12-19-2016, 04:08 PM
  #399
HioSSilver's Avatar
You're not even repeating them. You're just trolling. Scotty just stuck it in you.....robz aka vetteboy didn't have rockers, he thought his car was a bit over the top to be on the bolt on list. You just repeated misinformation like a dumbass. He's likely not on the list for the same reason the jpc 5br0 isn't on the list.
Old 12-19-2016, 04:11 PM
  #400
sw07gt's Avatar
I am repeating them doug, the ls1/ls6 fast list on here doesn't allow them. That's just a fact, I can't help it.
Quick Reply: Bolt on Mach 1 destroys bolt on LS1 Z28
