Ford needs a supercharger to compeet
#101
Ls6 ended it's life as a sedan motor. You could buy them for $3500 brand new. Not exactly high motherfucking end.
So now you want a custom pcm on you furd....figures. You didn't know i knew the ******* pcm wouldn't getthere did ya.....lol
Car is well documented at weighing that. It's not gutted like thr junk **** you're trying to compare me to. End of story.
I wouldn't need a build to drag your *** with boost if i wanted to. Slb would get it done easily .
I'm not comparing me to a slb mach. You brought that **** up after your own mach failure. I'd drag the **** outta one. A buddy had one with a turbo....i drug it to.
So now you want to compare a full built motor to me. Claiming that pos made 490 on pump. ....lol good luck making anyone believe that with no proof.
You are my bitch. I own you. The best thing you can do is stfu with your dumb bullshit.
#103
Seriously. I effing knew you were going to type that. I was almost going to type "yes, my car runs 12s". Well, my truck keeps up with a max effort, gutted, 5th gen. Good enough for me.
#106
#108
You can't even quote right you ****** moron.
#110
You didn't drag that car. You edged him by a fender with 2 ****** power adders on rg to his single power adder on pump and **** driving.
Tell us more about your cammed 3v performance
That makes 3 bolt on or cammed furds you've did that couldn't out run nathans no header having ls1
#111
#112
2-3 cars.....lol.
Not in that ******* vid.
Pump gas and meth don't equal 2 power adders and rg. I mean you were all about being fair when you wanted that mach thatcwas lighter than me to weigh the same
Come on man. Stop avoiding the 3v debacle. Post up your cammed times. Show how ******* awesom you are.
You do realize the only ****** thing you have proved is that furds ned to be moon boosted right.
#113
2-3 cars.....lol.
#114
I have another video. So what makes more power a YSI on 20lbs or a 2.3 TVS 17lbs/75 shot. I will give you a hint its not the PD blower. The 3v @ 3500lbs went 12.5 @ 111. Car had crappy shelf cams and not enough gear just to name a few issues with the combo. Still had no trouble running with the local cam only ls1 cars. You do realize that the lsa/ls9 take moon boost to do anything as well.
#115
+1 ultra
Lol you ******* idiot. Ive proved to you what a just ok bolt on ls1 can do your dumbass thinks a 111trap car is gonna run with a just ok cammed ls1. You're a ****** delusional moron.
Nothing wrong with off the shelf cams if you know how to pic them. Not every bidy needs a ****** special custom cam. Your **** was a junk 3v. There was nothing you could do for that pos but boost it until it spit it's guts out.
The goddamn shot gets compounded with boost you ****** moron and it helps cool the charge. Who the **** do you think your kidding here?
Lsa/ls9 don't need as much boost to make the same or more power.
#116
#120
It depends on the race. Probably a solid 98% of races on here are roll races. Mph will matter then. Even for guys that run slicks at the track then roll to the street on something different, their et don't mean much in the street race then.....but mph will.
To many variables in street racing to say for sure on any of them. But et does win at the drag strip.
