Street Racing & Kill Stories Basic Technical Questions & Advice
LT1 supra vs ecoboost mustang
Old 12-04-2017, 10:43 AM
DirtyMike's Avatar
Default LT1 supra vs ecoboost mustang
LT1 supra is aluminum stock ported heads and cam on a base email tune.
Mustang is full Bolt-on's and tuned.
Supra has not been dyno'd. Last time the mustang was dyno'd it made 380 torque to the wheels. Not sure of the whp though.
Thought I'd share.
Old 12-04-2017, 10:55 AM
Jake89's Avatar
FBO ecoboost stangs are no slouch, for sure. The old LT is putting in some work. Nice race.
Old 12-04-2017, 11:26 AM
DirtyMike's Avatar
Thanks. I give him credit every time we run. His ecoboost is pretty damn fast.
Old 12-04-2017, 11:44 AM
Jake89's Avatar
Yeah, just a tune really wakes those cars up. You definitely had the torque and weight advantage. However, it looked like top end was pretty even. Once you jumped out in front he kept pace.
Old 12-04-2017, 11:49 AM
DirtyMike's Avatar
I'll be installing a 52mm TB and a underdrive pulley this week just to try and get a little more distance on him. lol. We work together and its constant **** talk around the shop. lol
Old 12-04-2017, 12:20 PM
Mike Morris's Avatar
Port match the intake when you do the TB
Old 12-04-2017, 12:27 PM
HCI2000SS's Avatar
Good race. If that Ecoboost is making 380 tq it's probably making more like 300 hp. Ruining on any of these turbo eco motors, tuning makes a huge difference
ohioborn80's Avatar
Good run. Time for him to swap turbo.
Old 12-04-2017, 12:38 PM
DirtyMike's Avatar
To my understanding I thought that the TB opening was 52mm stock, and you only had to open it up for a 58mm?
Old 12-04-2017, 12:51 PM
meddlecho's Avatar
You should turn that ecotoaster into a f-shack for that visor.
Old 12-04-2017, 01:17 PM
hugger1975's Avatar
FBO and tune only made 380?
Geez...i made 360 with DP and tune
Either fords eco is behind chevys, or e85 is that good
Old 12-04-2017, 01:25 PM
DirtyMike's Avatar
The mods that I know he has. Intake, exhaust, and aftermarket intercooler, tuned. He may have other mods, I'd have to ask him.
Old 12-04-2017, 02:58 PM
Puck's Avatar
Close, it is 54mm. Nobody really makes a 54mm TB though (I think AS&M used to, but its pricy), so people go either 52mm (which is fine with stock intake) or 58mm and port the front intake.
You don't need to remove the intake to open the holes up so honestly might as well get the 58mm and open it up while you're in there - I did it when I was bolt-ons. I used oil coated rags stuffed in the intake with a shop vac nozzle mounted right up against where I was grinding. Vac sucked up almost all of the shavings as I cut, and the tiny bit that fell were pulled away by the oiled up rags when I removed them.
It won't help over a 52mm on a stockish motor, but it wont hurt either and is better then having to buy twice if you still plan more mods down the road.
$.02
Note that most aftermarket TBs for LT1s are glorified TPI parts so they usually don't have the IAC hole isolated into the manifold like a stocker. I recommend JB welding a short section of pipe or some bar stock to isolate it properly. If not, IAC air just gets dumped into the plenum and starves the rear cyl vs the stock setup that has small passages to each runner.
Old 12-04-2017, 03:24 PM
DirtyMike's Avatar
Thanks for the input. I already bought the 52mm TB though. I went with it instead of the 58mm because I read a lot about how if you are still stock cubed that it is overkill. I got a BBK one used off ebay for a steal so I'm not complaining. If I need to later on down the road, I'll upgrade.
Old 12-04-2017, 04:16 PM
BlkMach1's Avatar
Wondering...why the LT1?
Old 12-04-2017, 04:39 PM
DirtyMike's Avatar
The LT1 was given to me for free from my dad. Came out of a 94 Fleetwood. This car is an extreme budget build.
Old 12-05-2017, 01:03 PM
DirtyMike's Avatar
Came into work today and the ecoboost owner has been doing data logging and trying to get his tuner to get more out of it. lol.
Old 12-05-2017, 03:59 PM
BlkMach1's Avatar
He must want the ecoboom toon.
Old 12-05-2017, 05:29 PM
UltraZLS1's Avatar
He should just sell it and get a new GT.
Old 12-06-2017, 02:03 AM
Nick.H's Avatar
This ^
Quick Reply: LT1 supra vs ecoboost mustang
