LT1 Camaro vs Supercharged Nissan 350Z
Here is a run between my buddies LT1 Camaro and a Vortech supercharged Nissan 350Z. Races were from a 20 roll, LT1 car is cammed with ported heads and intake, and 4.10 gears.
Good runs! LT1 ran good and hit pretty hard from the go. Seems like that when he ran out of gear was when the 350Z caught him. That is the only downfall to steep gears though. You run out of mph quickly..
Exactly.. With my 4.10s I would also run out of mph around 125. After the cam install though, it continue to make power at a higher rpm so I run out 4th to ~6800/6900rpms which gets me to about 133mph.
How so like those cams on that Mach? It made 388 rwhp on stock heads and intake? I had VT stage 1 cams on my 04 Gt, and it gained only 15 hp lol. Same dyno both before and after
It was not a bad investment imo.
Yes...stock heads but there is an intake spacer installed. Also had to upgrade the fuel injectors and MAF meter after cam install...and retune
