lucille vs pray tune 6th gen
#481
On a fuel? Yea, I would hope it runs on fuel. You back to lying again on what fuel I use?? LMAO. I run jet fuel for that whopping 16* of timing I see on my logs, INTENSE!! But Im sure id be lying even if I posted a screenshot of the log
#482
sounds fair enough to me man , never denied the camaro beat me on the lower rolls his car shoots out like a bullet from 20 /30 rolls but it is fair to say that 35/40 and maybe the 45 rolls my car won those races , the issue was some members here did not agree with the outcome .
#483
#485
hhhmmmmm......how strange. You mean to tell me all cars don't do everything the same? Damn....that cray cray mang.
it goes through 2 gears will the camaro is in 5th......that's a pretty good advantage.
Useless post #1
man I'm glad i don't have to lie on you.
be easy for you to prove me wrong with a street dig tho......but that hasn't happened. Till it does I'm right.
that's how furd guys roll. They no care who's in front.
we all seen it poppa. You had that **** posted errywhere.
useless post #2
these furd guys get real upset with facts and screenshots pray.
Doh.....ultra layeth the smacketh down
because furd guys cry about errythang. They are of the liberal type and believe in participation trophies and if they aren't winning then they should rerace.
Useless post #1
useless post #2
The other mentions with the word CAM in it came from us talking about rawkers being LIKE having a cam swap because it changes it up.
oh well.. past stuff.. moving on
#486
#487
This is the second time Ive posted this video in response to the "you've never digged on the street". This video is on this forum and in 2 other posts. But you can continue to live in the nile bruv.
Dig vs a modded GTO while recording on street tires.
https://www.youtube.com/watch?v=GC8xUa_X8_0
#488
I pulled up and next to him and he said dig. following run was a 40. only got 2 runs.
#490
I would have to run all the numbers but I think the issue right now down low is that the car is over geared and spends all its time shifting up till 5th or 6th. The deeper gear would only exacerbate that issue, especially for drag racing. However, for the rolls that you guys do with your current tire height the 3.73 may work out.
Now, looking at the lower gear splits with say the 4.09 you could benefit from it if your tuner sets your car up to not start in 1st and skip gears on the front half. With the A10 from what I have head you can select starting gears and you can skip gears. In a drag race we are looking to get through the 60ft in 1st gear or our starting gear and have around 1K rpm splits on shifts. A deeper gear could allow you to do that if set up properly in the trans.
For your guys roll racing bit I would look at your start mph and end mph and plan my rear gear and tire height accordingly. Your set up should set you at your max rpm in your 1:1 gear at your end mph.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Oh oh wait..... What's up with that 1.29 60' slip you guys were posting in kik. Post it here please. Shows how much faster, & much more power, that car has than yourz. With the times & that almost 10mph more speed at 1/8. Along with a converter from what I've heard. Still cant 60' as fast as your pos M6 car.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Let's Narrate the video for those with short term memory loss and seem to forget what they watched by the time they started typing in the comment box.
Run 1 & 2. Camaro gets hit and stays way out. Stang cuts video off early. 2-0
Run 3 Stang gets slight hit, Camaro spins, pulls back goes around, the Stang pulls back up top around wins by a car to 150. 2-1
Run 4 Stang gets hit, Camaro spins, pulls back even, Stang pulls ahead by half car to 130. 2-2
Run 5 Even hit, Camaro gets out ahead and stays out a car to 150. 3-2
Run 6 Even hit, Camaro starts 1/4 car back, gets out a car, mustang comes back by 130. 3-3
Run 7 Camaro gets slight hit, stays out 2.5 cars to 145. Stang let's out first. 4-3
Run 8, Mustang slight hit, Camaro gets out a car, Stang pulls back at 140. 4-4
Run 9, Even hit, Camaro still ahead at 145. 5-4
Looks to me like they ran out most races...Stang cut video off early on 2 races and Camaro let off around 130 on 2 races. Other then that it appear that whoever gets the hit wins by 145-150mph. Coyote has stronger pull in the 130-150 range, Camaro is stronger to 120. If Camaro gets out it can stay out with less mods.
How bout you go do what you want & other people do what they want. K??
#491
Thats impossible Soflo. Record holder car going 11.0s 126 at our track? The people with the knowledge say Leo is a 130 car....So steeda should go 135 with all the extra work and less weight.
#492
Right? He did hit a 10.9 though lol. Lots of very knowledgeable people have stated it is not wise to compare slips from different tracks. I'm sure the guys getting 130 traps are very happy. Come down here & you gonna think sometin wrong wit your car. Like hiho does. Lol. Yea, everybody does it & it does give general idea I guess. Get all fastest guys in same track, same time, & see who really the fastest. Or any real race of coarse. Not keyboard race.
#493
#494
Heck yea. That's awesome. Last month they did run 10.6 @130 bout 500miles north at SGMP. Differences to car better CAI to feed CJ & converter too so....
#495
Just replying to the statement in bold. Very good info. Perfect. Just, everybody does different stuff so it's hard to find the right match sometimes. You got a car set for rolls & they want digs. & vice versa. ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
They are actually shifting to 7th just before the trap with the 4.09 gear. Maybe a bigger tire would help? Probably helps the most out of the hole. Here's a vid running at local track bout 3 months ago.
https://youtu.be/apT9Z49X-6U
Hey there. Uh, hopefully you would understand that & I wouldn't have to tell you. Duh.
Oh oh wait..... What's up with that 1.29 60' slip you guys were posting in kik. Post it here please. Shows how much faster, & much more power, that car has than yourz. With the times & that almost 10mph more speed at 1/8. Along with a converter from what I've heard. Still cant 60' as fast as your pos M6 car.![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Good write up. The only thing I don't agree with is the mero spinning on runs 3 & 4. If he spun it would be worse than that. No fight, just dont think he spun. Both cars were hookin good.
#496
but you dat dig racer from hell stippin dem digs errywhere......ooohhh wait.
only when you think it might help you is more like it.
sorry for long quote.. phone foruming sucks.. bs Doug. I didnt post that everywhere. I posted it joking in ONE thread. You are welcome to show me the many posts. If I did I do not remember. And I apologized to Phil in kik.
i don't save errybodies posts. I don't care that much. But I'm sure I'm not the only one to remember it. Phil even corrected you several times.
You had the best running bolt on 5br0 we had come across. They were good runs....i can only imagine what you did to other 5br0s. Now imagine that fatgen picking up considerable after yalls run and what it to them to.
so neither ran 130
#500
So there’s never a day in south Florida with DA below ~1500?
my car only runs marginally better after that with E85. C85 help even more I’m sure
Ive never run in better air than -100 or so.
Didnt smith run tge fastest ever stock time in a new gt in Florida with great mph and near sea level DA?
