Epic SRK B/S thread of 2019
#3123
Found the 20hd on amazon for 360. Bikeman lithium charger for 35. Yeah it’s kind of a lot for ~45 lbs weight drop. My current battery is 23 but it’s kind of weak at only 550 ca . Hot starts are iffy sometimes. So hopefully it will solve that and I’ll drop 15-20 in the process
other options can run slightly cheaper down around 250-300 with restart feature and less CA. For another 100 just said screw it and got the one I wanted.
#3125
#3136
Originally Posted by UltraZLS1
Even if true. How much weight can you really lose from doing that? Can’t be that much
#3138
Besides.....holes isn't gutting. You gutted yo stuff.
Erryone should be happy that i have did (w)hole reduction. Less holes but lighter parts should make the erryone happy and stop the
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
#3139
There is this imagination where people think other people care a lot more about removing airbags and cutting factory parts and **** than they actually do.
It's only mentioned because it's worth noting that someone was so desperate for WR that they did **** like that. It shows how max effort the build is/was.
The credibility of those people is only diminished when they act like those efforts were trivial. If they're trivial, then undo them.
-Confucius
-Confucius
#3140
Are you saying that cory coyote car was max effort? You saying Larry is max effort? Are you saying erry mustang at the track is max effort with a seat removed? Cause there's airbags in them there seats you know......Confucius
Seems as though alot of bitching comes from the ones either lacking the know how or just plain out being to lazy to do mods.....maybe they lack the creativity also.....
..more Confucius
To focus on one thing to consider a car max effort is pretty assign and closed minded. For example- my camaro. So far from max effort it's retarded. No alternative fuel, no race brakes, always ran with seating for 4, rain worthy tires on it. ****.....it never even got to run in it's most powerful form. I mean it's not like i was swapping out heads and using multiple cams to try and increase speed and thus reducing fuel economy, streetability and reliability.
..more Confucius
