Epic SRK B/S thread of 2019
#4002
Pretty basic rebuild of the ls6. It ran fine when i took it apart but it showed some pretty good wear on the cam bearings. So with 90k hard miles on i decided to rebuild it instead of taking a chance of it failing. After all it wasn't gonna get run any less hard.
Itwill be using the stock crank, stock gen4 floating rods and mahle forged pistons with 4cc valve reliefs for the bottom end. Those pistons were just a off the shelf piece that were light and had a nice ring pack.
The heads are old gmpp ls6 cnc that i cleaned up the cnc marks in on the intake side and opened up the exhaust side a bit. I had them milled .035 more for a total of .090. It should be around 12:1 compression. They will be running stock ls6 valves with psi 1516 springs ans i figured i would try some speedmaster rockers. They're a shaft mount . The cam came from darthv8r. It's the one he used in his 540whp h/c ls1 and it's a llsr. It's a 237/245 .654 .637 112.5 +2.
The intake is a msd that mamo originally ported and i retouched and fed by a duggy box. It came from 98m6 ws6. It's the one from his unfortunate fire that i fixed. Probably end up with a 105mm tb on it. 1 7/8 kooks and speed engineering tdx will finish it off and was previously used.
Are you going to run a maf?
The following users liked this post:
JayplaySS (10-18-2019)
#4004
I watched a stock 6gen run 12.2s all night last week in around zero da and he was blowing launches all night. 2.0 60fts. He could have run 11s stock. Trap was 115-116.
the new GT does seem to trap higher no doubt but the ET between them is neck and neck. 6g 60 fts a good tenth harder both hooking
too bad the stock trans tuning on the new a10 Camaro looks to be ****. It’s nothing compared to the bro’s who have them barking the tires on shifts with stock tune. The a10 Camaro got a neutered trans tune. It’s no faster than the a8. Might eve be slower imo
Fixed and Facts!!
#4006
BTW - I finished installing the TSP LT's and it took me 11 hours
I have stock mufflers with resonator delete and just added the TSP 1 7/8 long tubes with off road (cats) - this is the worst, most obnoxious sound I have ever had on any car thus far.
I just ordered a Manganflow true x resonator - this should solve the rasp, Jesus I pray
Just being honest - sounds awful
Chris25 (10-18-2019)
#4007
#4009
I ran one on my 2018 A10 GT, paired with the Roush AB.
#4012
I remember pulling the 6.0 apart after losing oil pressure only a couple weeks after buying it and found that the cam bearings were shot and you talked **** to me for days saying it was my fault lmfaooo.
#4015
How so again? You seem like adam schiff just making up dumb ****. Now you're like pelosi having a meltdown.
Again....please link where i made fun of you for wearing out your cam bearings in a few weeks.
#4018
Yea i don't think so. Thanks for providing no proof tho. Seems like all yalls evidence resides in the kik group after thousands of posts on here......weird. must have something to do with white washing those emails.
Now there has been a multitude of **** to make **** of your dumbass for......but making fun of engine failures i typically don't do.
Yes you are a hypocrite......or you woulda just said nothing or vary little about mines.
Now we're done bitch.
NW-99SS (10-21-2019)
#4020
