Epic SRK B/S thread of 2019
The following users liked this post:
NW-99SS (10-22-2019)
#4066
Yes it has steeper gearing. All the more reason for tm to intervene.
#4067
Agreed...DCT and mid engine isn't going to make it Dyno 60whp higher then it's advertised numbers. A Mid engine DCT car should show roughly the same loss as a front engine manual car. I know on the BMW stuff(both front engine), the Manual cars still dyno higher then the DCT. That is because the DCT is a wet clutch system where a Manual car is dry.
https://www.bimmerboost.com/showthre...ion)-vs-Manual
The ZR1 took some time to crack with a Global A ECU architecture, the C8 is suppose to get Global B. I am guessing somebody will find a way but if it costs what the ZR1 does to unlock that is going to suck for sure.
#4068
Sure but that don't stop them from using tm to soften the hit of the next gear to A- make things easier on the shift. B- help the driver maintain control. C- more components involved than just the trans so it's only as good as its weakest component. D- axle protection anyone??? Been a staple a timing pulling tq robbing bs since it's inception. And likely one of the main reasons behind me saying you ain't turning it hard enough.
#4069
Guarantee it has a **** ton of TM
and I’m still just not understanding those of you who are disappointed with a 123 trap at over 3800 raceweight and 495 hp. It should actually be a bit lower imo
c8 has exceeded almost all my expectations so far. It is a bit heavy. And I’ve also read they held back on the handling a bit to protect the average consumer. It has a bit of understeer. Supposedly because a mid engine car like this can easily end up with the rear end pointing toward the ditch in the wrong hands. Understandable
#4070
Tm is no doubt still there....and probably faster reacting to manage the power vs traction better. Just remember the tm is also there to help make is easier on parts to. That boosted camaro chihuahua ran the other week was a great example of tm still intrusive on shifts. .....which is something you'll never see on a dyno. We seen it on phil 1le vs poppa 5br0 to. It's been involved in phils vette till it got turned off. It's a top end killer and greatly hinders momentum from gear to gear.
C8 will probably pick up 5ish mph with just a tune. Maybe more.
#4071
NW-99SS (10-23-2019)
JayplaySS (10-22-2019)
#4074
At the end of the day one has to use some logic. If GM could get 650hp at the crank from a NA 6.2 engine and pass emissions they would have never put a supercharger on the LT4. 650hp is what a decent Heads/Cam LT1 makes with a cam that has overlap and a exhaust setup that won't pass emissions. The LT2 isnt making that kind of power plain and simple.
#4075
#4076
I don't see a LT2 making 80-100hp more then a LT1. There wasn't enough changes to the LT2 to support that much power gain. They share the same bore, stroke, compression, heads, throttle body. The only difference is the Intake manifold, oiling system, slightly different cam, and exhaust.
#4077
7 Second Club
That’s a pretty happy dino.
