Epic SRK B/S thread of 2019
#5301
7 Second Club
#5304
Because yall say alot of stupud **** that's not true. I've posted stuff about it on this site several times. People has pm'd me about it too. He8not interested....he's just being his normal bitch pos self.
I try to avoid designing anything that gains weight. It's a net loss in weight.
#5305
7 Second Club
Would explain why we only see parade and show cars with them.
Looks good though!
The following users liked this post:
JayplaySS (01-26-2020)
The following 2 users liked this post by OneSlowV:
AnnivSS (01-27-2020), islander033 (01-27-2020)
#5311
If I was charging 4 digit prices for an airbox/intake id be posting some test data before I even had the first one for sale. Much less after 7 have already been sold. I wont be bold enough to tell you it will or wont work better than "X" intake, but I will be bold enough to tell you that it could be the best thing since sliced bread and not be worth a **** without data.
#5312
Wtf did you not understand about me having some data?? On top of that it will greatly depend on end user installation and how they determine to feed it. I feed mine with 2 4.5" velocity stacks. The id of the duggy box is larger than the od of chris1313 tubing. It's also fully dd'able with filter provisions. They're kinda 2 different things.
Do you think bitchlander is in the market for one? Should i be wasting time trying to sell him one? How do you think it would hook up to his turbo or blower fitting on something it wasn't designed for?? Do you think he's just being his bitch self?
Not that i care to even make anymore really. At 1k it's no great money maker. It's just something i do because i can once in a while.
#5313
How about RWHP increase? Drag strip data would be useful from an auto car leaving at same RPM with traction.
No data. For $1k I would expect some more info than "in my mind it helps the car go faster!"
#5314
Where did i say in my mind it helps the car go faster? That's not data. The data comes from the map sensor and somewhat from the dyno. But there were more changes than just that on the dyno.
A drag strip could be useful. But there would still be no back to back data same day same track because of the installment of it. I'm not gonna do it. Like i said i don't care if i make any more. I didn't try to sell the ones ive made. Guys has approached me about them wanting one. When i got a few guys wanting them i made a batch.
I'm sure every part yall have bought came with a guarantee to make you faster.
#5315
I have never bought a performance part without some sort of proof that it was an upgrade. Maxing out the factory sensor doesn't necessarily equate to the car going faster. Thats fine bud, you dont have to prove **** to me because I wouldnt spend $1k+ on an n/a air intake anyways. Just saying, you have zero factual data posted anywhere regarding this piece, never been down a track. Its been on a dyno with "other things changed on that run". I mean how many stipulations do you want to add to it and just expect us all not to say ****?
#5316
So you're saying every part you've bought came with a guarantee of how much faster you were gonna be......go the **** on with that dumb ****. Way to many variables. I'm sure all the guys that bought ported heads and cams thought they were guaranteed to make more power and go faster than a bolt on ls6 to.
Maxing out the factory sensor means something. Especially when most don't even make it to 95kpa. What's yours run at?
Yup on the dyno with other changes. I don't have a dyno to constantly test individual things. Since every part you bought came with a guarantee on power i guess you assume that is always perfectly accurate to.
You probably never read the fine print and I'm sure you run a tornado and a tb spacer to stack dat hp up. Got you some split fires up in dat biatch ready to spray dat guaranteed 150 shot cause you gonna be mads if it goes over or under a 150 since it's supposed to be 150 guaranteed.
How bout turbos/supercharger?? They make a engine run at higher map readings to. Is there a guarantee on how much power they make?
OneSlowV (01-27-2020)
