Epic SRK B/S thread of 2019
#5322
So long story short is rug has no answers and as usual he tries to bring up his engine swapped Ford rear'd Camaro to take the emphasis off of the original topic.
I've never bought a pair of heads, a TB, etc. without seeing how much they're capable of flowing, and/or before and after results from someone who has made the change.
#5323
So you're saying every part you've bought came with a guarantee of how much faster you were gonna be......go the **** on with that dumb ****. Way to many variables. I'm sure all the guys that bought ported heads and cams thought they were guaranteed to make more power and go faster than a bolt on ls6 to.
Maxing out the factory sensor means something. Especially when most don't even make it to 95kpa. What's yours run at?
Yup on the dyno with other changes. I don't have a dyno to constantly test individual things. Since every part you bought came with a guarantee on power i guess you assume that is always perfectly accurate to.
You probably never read the fine print and I'm sure you run a tornado and a tb spacer to stack dat hp up. Got you some split fires up in dat biatch ready to spray dat guaranteed 150 shot cause you gonna be mads if it goes over or under a 150 since it's supposed to be 150 guaranteed.
How bout turbos/supercharger?? They make a engine run at higher map readings to. Is there a guarantee on how much power they make?
1st: Guarantee of how much faster? No. Some sort of data backing up that it was indeed a performance improvement? Yeah.
2nd: Mine doesnt make jack **** considering my engine is behind my car on a stand.
3rd: Most people who are producing and selling parts will do at least one controlled dyno session with only their part replaced to prove performance gains. But if youre not worried about it and not trying real hard to sell anything, then by all means you do you.
4th: Im not even going to dignify that with a response.
5th: Turbos/Superchargers are known technology and if there isn't a performance gain from installing one then you f-ed up big time and need to go back to munching on your crayons.
#5324
7 Second Club
The following users liked this post:
AnnivSS (01-27-2020)
#5326
2 so you have no clue on what it will make i guess after buying it but yet want some absolute numbers from me
3 it has been on a dyno so i have a good guess just as anyone else would.
4 you to stupid to make up more bs i guess
5 turbos and superchargers have been around way longer with far more tests. And you likely still couldn't guess within 20hp of what one would do for your combo.
Besides.....i wouldn't ******* make one for you anyway.
being around you is guaranteed to make someone dumber.
HioSSilver (01-28-2020)
#5328
Sure i have answers. I have answered. If your to stupid to understand it flowed enough to max out a map sensor vs map sensor being below ambient then you're a ****** retard.
1 read above
1 read above
Before you call people stupid and dumb...... you should probably make at least some small attempt at halfway proper grammar.
#5329
NW-99SS (01-29-2020)
The following 3 users liked this post by Chris25:
#5336
7 Second Club
Mike Morris (01-29-2020)
The following 2 users liked this post by HioSSilver:
Chris25 (01-29-2020), Mike Morris (01-29-2020)
