Street Racing & Kill Stories Basic Technical Questions & Advice
Owned.
Old 07-05-2006, 09:52 AM
  #121
BLKWS.6's Avatar
300BHP and I have no problem, like me, sometimes I belive what he means to convey, and the general air of what he DOES convey differ. Yes, he did PM me and was as helpful as someone could be not seeing the car themself.
Old 07-05-2006, 10:05 AM
  #122
300bhp/ton's Avatar
When do you think you'll have your new carb setup on their?
Old 07-05-2006, 12:36 PM
  #123
AROD427's Avatar
Originally Posted by Stanger88
I have killed my LS1 in a clean race. I also know for a fact that unmolested GT40 iron heads will put a 302 in the 10's (read MMFF this month). When I get a carb that both primaries AND secondaries will open on, I should be in the low 13's on a street tire at around 103ish. Right now, I ran 14.4 on only my primaries, imagine if your TB only opened half way when you wooded it...
I have two mustangs and I can honestly tell you that I would never use GT40iron heads.
There is no comparison between GT40 heads and a box stock any brand aluminum head.
the difference is your car struggling to run low to mid 13's with the Gt40's and your car running very easy mid to high 12's with aluminums.
to each there own. just my .02 cents. it seems like your focused on wanting to beat stock LS1's good luck and I really hope that carb helps I would really like to see how fast you can get your car on the GT40's.
  #124
Proud2bSS's Avatar
Hell yes it will. Depending on whos driving it lmao. nah, I built this car to take a bone stock LS1, nothing more, nothing less. That was the ENTIRE plan behind 2 years and 15 thousand dollars of restoration and mods and re-engineering. It looks like I shall have success, or VERY CLOSE to it. It will achieve its goal, and nothing more--or less.
Not trying to demean your ride or your achieved goals. The point is: Did either LS1 you beat have 4.10's (or comparable gearing in the A4)? We're talking a high 12-sec potential with just a gar swap.....and the driver has at least DRIVEN the car hard a few times.
4.10's in an M6 is a pretty good difference over an A4 or M6 with factory rear gears.
Of course, 4.10's are NOT stock, and it was your goal to beat a factory stock LS1 car. So kudos if you can pull that off after you get everything running right.
Old 07-05-2006, 01:19 PM
  #125
NOTAV6's Avatar
im actually not sure stanger i need to find out though lol ..... ill put a thread up in one of the tech sections and see what i can find out
Old 07-05-2006, 11:03 PM
  #126
BLKWS.6's Avatar
I agree 100%, alum. heads rock, but the engine came nice and purdy in its crate with a 345bhp/345 tq rating. That is 20# more tq and the SAME hp as the ford engines have, according to dyno's of similar motors they are the same pretty much. Anywho....
The carb should be on in 2 weeks max.
Thankyou for the interest
4.10's and an LS1....hrmmm, I take your point, but wouldnt it suprise you to know that a stock 05/6 GT with 4.30's and a manual will trap as fast as some of the non-freak LS1 cars?
Old 07-06-2006, 12:09 AM
  #127
joewee350's Avatar
You can put 10 carbs or whatever on a turd but its still a turd. LOL. Im just messing with you. I dont think your car is a turd. You say this carb swap is going to knock 7 tenths off your 1/4. I will believe it when I see it.
Old 07-06-2006, 03:06 AM
  #128
BLKWS.6's Avatar
well, if my secondaries are not opening then I am running on 670/2 = 335CFM. I dunno...we will see.
Old 07-06-2006, 03:34 PM
  #129
300bhp/ton's Avatar
I 4.10's and an LS1....hrmmm, I take your point, but wouldnt it suprise you to know that a stock 05/6 GT with 4.30's and a manual will trap as fast as some of the non-freak LS1 cars?
I'm not too certain about that, unless you are comparing a manual GT against a auto Fbody.
I have a vid from JMS running 4.30's, Street ET's, CAI and their performance chip (tune).
12.43 @ 107mph
Nice ET but a well driven M6 Fbody should be 107-109mph range.
Old 07-06-2006, 05:56 PM
  #130
BLKWS.6's Avatar
^no arguments there, but gears alone get you a 103ish trap and thats up from 99 normally. Not bad for a single mod...
Old 07-09-2006, 12:15 AM
  #131
AROD427's Avatar
[QUOTE=Stanger88]I agree 100%, alum. heads rock, but the engine came nice and purdy in its crate with a 345bhp/345 tq rating. That is 20# more tq and the SAME hp as the ford engines have, according to dyno's of similar motors they are the same pretty much. Anywho....
what? are you saying that the GT40's will make as much power as aluminum heads? I dont understand your post.
Old 07-09-2006, 03:42 AM
  #132
BLKWS.6's Avatar
Yes, my GT40p's make as much hp as out of the box GT40 aluminum swirl heads.
THey are 1.5pnts higher in compression, according to the 5.0 ford manual someone actually figured out that ever .5 in compression raise equates to 15 bhp, so while they dont flow as well, they have a LOT more compression going for them and that is the great equalizer, plus the flow velocity is KILLER! on these heads. They flow 200 CFM through 1.84 intake valves. THat is compared to a 2.02 and 225 cfm or so. (figures at .550 lift).
At any rate, the combo should lay down just south of 300whp and I am desperately hunting answers, carb tuner swears my secondaries dont open--im buying a DP, SHOULD! fix it. We will see.
Old 07-09-2006, 11:07 AM
  #133
Car RamRod's Avatar
I wouldnt compare them to gt40 swirls though, they arent the only aluminum head out there. IMHO, on a mild modded car, a good aluminum head set and a cam is equal to performance with a blower under 8 or 9 lbs.
Old 07-09-2006, 11:55 AM
  #134
Proud2bSS's Avatar
My point exactly. A gear change should be one first mods to ever consider if you want to lower ET's/increase trap speed w/o touching the motor. The right gears in the right application makes a very nice performance enhancement in most any ride.
Old 07-09-2006, 12:39 PM
  #135
BLKWS.6's Avatar
I agree ram rod. At any rate, heads,cam,full bolt-ons appear to have done nothing over stock for my car. But I will bolt the other carb on and see if it makes a difference
Old 07-09-2006, 07:29 PM
  #136
Car RamRod's Avatar
Honestly If I was in your position Id be happier that its still slow as hell instead of just not as fast as it should be. Sounds stupid, but this way you know for sure that there's a huge problem (carburetor like you said). Get enough gas dumped in there and you should be back in business.
Old 07-09-2006, 09:13 PM
  #137
BLKWS.6's Avatar
I guess you are right, all my cylinders fire and they all have compression, a dead cylinder is the only in-motor thing that could cause this pretty much. I suppose you have a point. I will know Friday when I bolt on the 600DP.
Old 07-09-2006, 09:37 PM
  #138
Car RamRod's Avatar
Hopefully. Some people would disagree, but IMHO, if a guy who knows how to tune carbs picked out the problem that fast he's gotta be on the right track. Either way, time will tell. GL
Old 07-09-2006, 09:47 PM
  #139
BLKWS.6's Avatar
I hope so, he picked it out over the phone, then drove it around the block andsaid he was 99% sure, then I found a site saying with the spring I have, it takes until 5700 rpm on a 350 with no air filter to fully open the secondaries...I have a 302 WITH an air filter...I dont think they are really coming open.
Old 07-10-2006, 01:58 PM
  #140
AROD427's Avatar
who uses GT40 swirl heads? that is big time old school, a really decent head like AFR and TW will outflow those GT40's like nothing power wise there is no comparison. I think the biggest problem with your build is your choice of cylinder heads, and your choice of going to carb.
I am awaiting to see if this buildup can break mid 13's.
To quote someone from The Corral.net "You spend more money trying to save money" Some people just have to learn the hard way.
Quick Reply: Owned.
