Are vettes really that fast?
Well tonight, we had a um airport runway closed down for us and I raced my friends vette. I think its an 01, it has intake, and a catback, and I think it has a tune. For a little background info on my car, I have whats in the sig. Before the dyno tune, ported intake manifold, and 58mm throttle body I ran a 12.4@114 in 80 degree weather. So back to the race. We went from a slow roll, ~30mph, both of us are 6-spds. The first race he was staying right next to me, so in 3rd gear I got pissed and sprayed him. Then we go again, a 2nd time, motor vs motor, 30 roll, and we were DEAD even up to ~135mph, with him inching on me topend. My car doesn't seem down on power, I dunno what gives. Are vettes that much superior to us?
Edit, I have heads/cam/true duals, ect. I put down 375/360 before the ported intake manifold, and ran a 12.4@114 in 80 degree heat before the tune, true duals, and manifold.
If it was a Z06 I could see it as the power was probably close to yours and they are under 3200 lbs I believe. A plain C5 w/ those mods wouldn't be making more than like 320-330 rwhp on the high end, you should have pulled him if that's the case. The standard C5 is only marginably faster than a LS1 Fbody, power is virtually the same so w/ 375rwhp you should have owned him I would think...
And the fact that the original poster has an LT1.
Im not downing on the LT, but I know its not known for its top end.
Also- what gears do you/he have? that may have played a part in it as well.
I second Cgillies- the C5 has a very low drag coefficient that's probably the explanation from him pulling away from you top end.
I also have a Vette horror story, I'm not really sure what to make of it- Halltech intake only on a FRC and it whored me from 25 (my best spot.) I took off as strong as always but I can always hook from 25. He spun the tires like crazy at 25 and just kept pulling and pulling. Probably put 1.5 to 2 grey hounds between us by 130.
Thing is the guy is an ***hole. he took the jump at second honk like 3 times that night, and his passenger kept telling everybody that you can never let anyone know what your mods are.
Don't mean to hi-jack thread. So yeah, if the guy wasn't lying I really want a FRC.
Seen a yellow C5 a couple of weeks ago at the track. Mid to high 13s wit 101-104 trap speed! It was a young guy who could not drive(driver mod) and I was pretty dis. So I guess my statement doesnt really mean anything.lol
Your trap is pretty good. Id say you should beat an I/E only C5 without problem. Higher speeds the vette should start pulling, but through the quarter you should have taken him no problem with the times you claim. Are you sure his only mods are I/E? Longtubes?
My car is full bolt ons minus a pulley and I ran a best of 12.3@115. My vette weighed in at 3130.
The vette is faster because its more aerodynamic, lighter, better weight distribution, ect. All those things add up. A lot of people think because both cars have LS1's, they must be the same in speed. I also laugh at the people who think the vette is an overpriced camaro or trans am.
The vette was faster because the other car was an LT1...had it been an LS1 camaro, the vette gets destroyed.
Just google a 2001 Corvette and most sites give an ET of about 13 sec flat stock in the quarter. You say you ran a 12.4 before adding even more mods, so you must be pretty close to 12 flat now. Is that with the spray or not though? If you did that without spray you should've killed the C5, if not the outcome seems quite reasonable.
375Rwhp is a lot of power. That vette with his mods probably makes about 320ish...I can't see him trapping much more than 110. 4MPH is a big difference when you race someone. From a low roll (30mph) you should have pulled him pretty hard and kept going. Since both of you let off in 4th, i don't see how the vette could have ever started pulling.
Either something is wrong with your car and it doesn't make 375/360, or that vette has more mods and is putting down at least 350Rwhp. Because that's about how much he would need to pull on you...
