Street Racing & Kill Stories Basic Technical Questions & Advice
Which slicks to use on public/dusty roads? Can't match AWD cars launch
Old 03-15-2011, 04:43 PM
  #81
Vetal's Avatar
Originally Posted by Lickeyman
Ditch the m6 and get an a4 with a 4k stall. Problem solved.
It's so curious that after 3.5 years I did exactly that 3500 stall though
Old 03-15-2011, 04:49 PM
  #82
The Manalishi's Avatar
I realize you are the OP, I realize that you have been here a while. What baffles me is bumping this to say that.
Old 03-15-2011, 05:52 PM
  #83
92builtbird's Avatar
People don't forget. Or should I say person
Old 03-15-2011, 06:24 PM
  #84
Empatho's Avatar
Originally Posted by jermzz
everything looks ok for the most part except your shock / spring setup. Thats huge. Your shocks are not made for drag racing at all.
Ditch those, get some hal qa1's all the way a round with 275 front springs and put stockers in the back. Also pick up a drag bar.
throw those 10.5 x 16 Et streets back on your car. Drop those bitches to 11 psi (cold pressure. once you do a burnout you'll get 2 or 3 psi). Get some of that loved VHT trackbite everyones talking about.
Do all of this^^^ relocate the battery to the back and also remove the front swaybar. If you cant hook with the tires you have after doing all of the above its time to stop racing there or pick up roll racing.
Old 03-15-2011, 06:35 PM
  #85
camaroboy14's Avatar
SO op you did a m6 to a4 swap?? Did it solve your traction issue? I just read this whole thread, and it seems you did the hardest suggestion of them all. Lol but idk...
Old 03-15-2011, 06:53 PM
  #86
blown99bergerssclone's Avatar
What about wider tires? Can anyone tell whether they'll fit?
I have seen posts where guys say they have fit a 13" wide tread pattern out back with perfect offset and bfh and fender rolling. I plan on trying it but not that far yet.
Old 03-15-2011, 07:46 PM
  #87
Vetal's Avatar
Well, yes, I decided to do what looked easiest, and swap to A4.
LOL.
OK, during these time not much changed. I've turbocharged my LS1. Put TC78 in it. And now I've gone berserk and ordered built 4L80E from Jakesperformance and triple-disc converter from Circle-D. Not the most common way to improve traction, I know lol.
Before turbo, car went best ET 12.97@110mph on small MT ET Streets. Then after turbo, it went 14.1 on 28x11.5 ET Drags LOL.
I was going to get some used QA1's for the front, but didn't have enough time.
So now my 4L80 is in the beginning of it's 7000 mile journey to Latvia. We'll see how it ends. Maybe I will have another chance to order front QA1's
Old 03-15-2011, 07:49 PM
  #88
Vetal's Avatar
Oh BTW, why didn't anyone mention LCA relocating brackets? Are they useless?
Yes, I'm going to remove/loosen front swaybar
edit: 28x11.5" ET DRag slicks fit very tightly, I will have to BFH some more
Old 03-17-2011, 04:14 PM
  #89
dkbmxer002's Avatar
leaf blower (or a couple), vht and some mickey thompson 325's and have fun...
Old 03-17-2011, 04:54 PM
  #90
Vetal's Avatar
blower is good, but we still have very very very crappy tracks here. So I need unreal weight transfer I guess?
Old 03-17-2011, 09:39 PM
  #91
FOG52's Avatar
A line lock, MT streets, adjustable shocks and a good burn out is probably your best bet.
But AWD kills even at a prepped track also.
Old 03-21-2011, 04:51 PM
  #92
Vetal's Avatar
What springs should I get with QA1s - 275 or 300? Keep in mind I have heavy nose with 4" intercooler hanging in the front of the tires
Old 04-08-2011, 05:08 PM
  #93
67RSCamaroVette's Avatar
I have 275 springs on my QA1's, with an iron block.. They're cranked all the way up, you could get away with either spring.. Id do the 275's though, since you have about the same front weight as I do.
Old 04-08-2011, 05:25 PM
  #94
06GTOKID's Avatar
I always roll out of my burnout way pass were we are lining up on the street. To get the hot robber down in front of me so it cleans the road and puts hot rubber down to stick to.
Old 04-09-2011, 05:03 PM
  #95
Orange Juice's Avatar
Do you have a line lock?
Old 04-09-2011, 05:19 PM
  #96
willizm's Avatar
LCA's with relocation brackets helps a ton. Do you have a torque arm and subframe connectors?
Old 04-09-2011, 05:22 PM
  #97
willizm's Avatar
As for the topic, AWD shines off the track so well. Even on a dusty back road you hook and book without having to think twice about road conditions.
Old 03-10-2012, 09:14 AM
  #98
Vetal's Avatar
Here's video to illustrate our track conditions: 700HP Evo destroys 1100HP drag Camaro
http://www.youtube.com/watch?v=M-S5VK4kjGc
Old 09-26-2012, 05:43 PM
  #99
Vetal's Avatar
A little update in the setup!
I've got my Strange single adjustable front shocks finally and now I'm in the process of installing (though I broke top "stud" on one of them after torquing to about 37lbs).
I was a bit surprised to see that fully extended these shocks are not longer than my Bilsteins, so they will not allow the front of the car to raise higher. I thought they would be much longer. I'm thinking of getting new "stud" machined a bit longer to allow the car to sit higher relative to the shock. Is this a good idea or not? That would help weight transfer I guess?
Old 09-27-2012, 08:11 AM
  #100
NOLAG05's Avatar
You still trying to beat the AWD cars? What pressure where you running in the MT's?
BF Goodrich KDW2's might help in the dirt since there tread pattern is pretty aggressive or try these... Toyo R888's might be your only hope...
Good luck bro...
Quick Reply: Which slicks to use on public/dusty roads? Can't match AWD cars launch
