Ran a stock 07 350Z tonight.
#201
Overhead valve engines are pushrod engines, Overhead cam engines are overhead cam engines.
http://www.samarins.com/glossary/dohc.html
http://en.wikipedia.org/wiki/Overhead_valve
#202
14 Second Truck Club
A Lotus is a tad bit quicker than an S2k. So do you not consider this a sports car?
A camaro is not in the same league as an S2k on a track. Granted it might pull similar times, but thats due to the power advantage on the staights.
Ask any Corvette, Evo, Miata, Porsche, Viper owner, about the capabilites/differences in the cars and they will tend to agree with me. You need to modify the suspension to a camaro, just to hang with an S2k.
#203
So which is it? You say it will pull similar times, but then that it cant hang. IMO a Camaro is not a true sports car, and although the S2000 may be a sports car in many opinions, it is on the lower end of the spectrum. Same with a Miata. An Evo is not a sports car IMO, and I would bet you would find many people who agree. Does an Evo handle well, sure, but it is really just a modified sedan. But then again a lot of it is opinion.
#204
If I'm not mistaken a "sports car" has two seats only and is designed to be sporty. A "sports coupe" has 4 or more seats and is designed to be sporty. A "muscle car" was built in the late sixties and early seventies and was fast in a straight line. A "pony car" is the same as a "sports coupe" but in a smaller more nimble package and typically used to describe the Camaro, Mustang, the Twins (Challenger, Cuda) and the Javelin. The AMX is the wierd one because it only had 2 seats. These are the definitions I grew up with through the 70's until now. I hope they still apply and I'm not that old.
#206
I suppose your car also has a motor instead of an engine. Please read everything contained within your link as the link proves what you said to be mostly incorrect. OHV applies to all engines where the valves are in the head and not in the block. I am not bashing you at all you are simply incorrect and need to read what you post before accepting what you believe to be true over what is true. The link states in very simple terms exactly what I posted.
Even GM themselves uses the term "OHV" for their pushrod engines:
http://www.gm.com/explore/technology...info_specs.jsp
"The LS7 7.0-liter V-8 engine for the 2006 Corvette Z06 has 505 SAE certified hp and is one of the first automotive OHV production engines capable of running up to 7100 rpm."
#207
Unless you've been living under a rock, OHV has been commonly accepted as the term for pushrod engines, while it does sound like it can be applied to all engines with valves over the cylinders.
One of the first production car engines with valves over its cylinders to rev to 7100RPMs? No... One of the first production pushrod engines (OHV engines) to rev to 7100RPMs.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
#208
OMFG.
1) OHV generally refers to pushrod motors. By generally I mean in the automotive press, most discussion, etc. Similarly, OHC refers to those cars coming with OHC. So while not technically a distinction, it is in reality. You guys know reality right? Its that place to the left and right of your screen.
2) Technically the original definition of sports cars was a open top 4 banger RWD roadster. Who gives a crap? While we are on that subject, the closest to an official definition of a "muscle car" is 4 door family sedan with a burly engine and a driveline. Who cares about that? Everyone loves calling Mustangs and GTOs muscle cars. Shoot, many people consider the GTO the first muscle car. Which is horsepoo BTW since the Bel Air with a 409 came before it.
3) To sum this up:
Semantics is uselss BS
350Zs have gotten much faster stock over their production run.
Any given night at the track will show you a stock Fbody/novice driver run a time slower than what a awesome driver could get in a 350Z stock.
For the third effing time yes domestics are better drag racing cars.
For the third effing time imports can compete none the less.
For the second effing time some tasks and upgrades are actually easier with an OHC motor. You dont need to remove a radiator or tilt the engine to pull a cam for one thing. And for another the heads tend to be less of a restriction as power levels go up and for another the valve train in stock form can often handle higher RPM since it weighs less and has fewer parts than OHV ( oh, I'm sorry, pushrod )
3) To sum this up:
![Hijacked!](https://ls1tech.com/forums/images/smilies/myhijacked2.gif)
#209
OMFG.
3) To sum this up:
#210
I've raced two so far, I think one was a 05 ?? and the other was a 06'. I rock the socks off of all of them from a dig, and from a roll still too the win. And remember people I only run 1.4's-14.3's on the street. Alot of people are right they just don't know how to drive them I guess.
