Evo8 dyno numbers
correction I did not mean to put "with stock internals" since 25 **** us off did not specify that in his last post...... Only 2 cars huh... Almost any domestic v-8 is capable of that power with the right parts
Typical domestic comeback. There are no answer's for what you have been dealt. You stuff 5.7 liters of motor inside your 3500lb+ car and you call it muscle. So what do we call a 2.0 or a 2.5 making the same amount from the factory.
In the end both types of setups go about reaching the same goal in different ways. Thats my take on it. Not only are you bias but but its pretty obvious you truly don't understand certain principles. Its clearly shown through your ignorance.
Did you read the post. I clearly stated that there are only 2 that I can think of. So I guess they are the cobra and GN.
Tell me how am I pissing you off? I clearly asked why is it that there are 4 cyl. making what you are from the factory with less displacement. Isn't that a logical question. Who gives a rats *** if it's FI or not. Obviously you didn't have a problem naming a GN or an 03 cobra.
Like I said over and over again. It isn't like Japanese or European car makers can't make the power. The market is not there. Plus there are certain regulations that are put on an x amount of hp. Have you noticed that most of the cars overthere are rated at 276hp, and nothing more.
what 2.0 litre engine mkes that power from the factory...... EVO NO STI NO If you want to compare that 436 hp evo with just a few bolt ons it only take one bolt to make that much hp with a ls1 NITROUS...... There that evens the playing field. One power adder to another. You act like an evo or sti is a lightwieght. "5.7 and 3500lbs" what does an sti or evo wieght 3200lbs? YA
***** in your court now.
Goodnight 25POS. Sounds like you have a little (pun intended) case of ***** envy. I think if you jerk off enough to your ricer catalogues, maybe, just maybe, it will grow.
We have BIG engines. We sleep well. It's the American way.
GN and cobra.......hummm both FI let me ask you a question.... Do you see a trend here, all the cars you are talking about are FI also. Maybe its just because FI cars from the factory are built a little stronger internally and its easy to pumpup the boost. Like I said before almost any domestic V-8 is capable of 600hp...... Many with FI!!!!!
Listen up POS, I'm only gonna say this once.
Imagine this. It's the 1800s, somebody challenges you to a duel, anything goes. You, being the master of knives and general combat, bring many different kinds of knives and cutlery with you. The man who challenges you, is a lawyer. He never fights. You show up, all ready with your knives. The lawyer walks up, pulls out a pistol, and shoots you. BANG! You lose.
This can be strongly related to the whole import vs domestic thing. If a stock LS1 pulls up to a stock Integra Type-R, the LS1 will most likely smoke the **** out of him. What's the Type-R driver gonna do? Shake his fist out the window yelling "Oh yeah! Well I make 100 horses per liter with a more high-tech engine then you! So ha!" Do you REALLY expect the LS1 driver to give a ****? He just smoked the Teg driver's ***. He's probably laughing as he just put a few bus lengths on him.
All this talk of technolgy doesn't even really matter. Who cares who has better technology? Whoever crosses the finish line first, wins. As long as he plays by the rules, what else matters? American motors have made power by using high-displacement 8 cylinder pushrod engines for 40 years. If it works, why change it? Hell, the stock LS1, a pushrod 5.7 liter 350 cubic inch v8 will smoke most of the stock "high-tech" import engines out there.
Technology doesn't always win, buddy. We're still smoking your ricey asses every night on the highway. I bet for every Import that smokes a Domestic, there are 10 more domestics smoking imports on that same highway in 24 hours. Until you can beat us, or even run with us, shut hte **** up about your high-technology bullshit.
Oh yeah, one more thing:
KISS MY LOW-TECH PUSHROD DRIVING ***!!!
I think it is a big deal. It sets higher standards for which to set goals for. How many cars(domestics) can you name that can make 600 plus reliable hp. I can only think of 2.
Yes a 2 valve motor making 8000hp is very impressive by any means. But I think we need to talk about something that is relative to 99% of people on this board.
So what physics are you talking about. Not displacement again! There are two ways to counteract this. For one revs. I don't recall the equation, but x amount of rpm's will give you the necessary cfm to compensate for having a smaller motor. How do you think BMW was able to make 1400hp out of a 1.5 liter, by revving to 14,000 rpm. And the second is turbocharging.
If technology wasn't the key for making power, then tell me why almost every car maker has taken the VVTELC(vtech) from Honda and installed it on there cars. NISSAN,BMW,MERCEDES,TOYOTA,SAAB,ACURA, and soon to be FORD with there 2004-5 mustangs. It's proven.
So tell me this. Why are most of the imports(performance)making just as much power than you from the factory. Seeing that you have twice the motor and 3 times the displacement. Where is all the power going too. Where is Chevy and Ford putting it in. Could that be magic! Knowing that you have 5.7 liters to work with, seems like you should be making more than 260 and 320 horses. Not that impressive in my opinion.
What is impressive is, taking a car that has been out for 2 months and running 11.4's without even opening the motor.
So until you can make use of your bigger displacement, please dont bring up cubes anymore.
they make the same power with smaller displacement from either forced induction or a super high rpm motor with no bottom end i.e. s2k its only 20hp less than a gt stang right? well the stang literally has twice as much torque and doesnt have to wind to 8300rpm to hit its power peak
.variable valve timing systems are about driveability, has nothing to do with racing or overall power output. theyre just trying to make a gutless motor less gutless when you stomp on the gas for highway merging. unless of course you forgot that most honda racers ditch the vtec setups to reduce valvetrain weight?
a motor makes power ONE way, bringing in air. you can do this artificially i.e. FI or spray or you can do it n/a through cubes or revs. the slight amount of extra revs a small motor can go over a bigger one wont make up for the gross lack of displacement. unless you want to start comparing 9k rpm big blocks with 10 or 11k rpm 4 bangers
typical little guy syndrome, trying not to be overlooked and ends up coming off as a dick.
however, it basically comes down to the fact that the quickest and most powerful internal combustion engines on the planet are still 30 year old dinosaur motors with a halfass inefficient power adder
I RACED ONE OF THEM THE OTHER DAY ,
THE FIRST RUN WAS FOR 100$ WON BY 3-4 CAR LINKS
2 RUN I GAVE HIM 2 CAR LIN(BUT I CAN SPARY 75SHOT) AND WON BY 4-5 CAR LIN,
MODS IN MY 2000 TA (SLP LOUD MOUTH,FREE MOD,nxKIT)
I've heard of stock internal ls1's putting 800 + horses to the ground with a turbo, who cares, its not going to last long, some will some wont, depends how you drive, you could drive a blown 800ci alcohol motor w/3500 hp for longer than a 1/4 mile, but whats the sence, we want our street cars to last, we know what the ls1's can handle, although you can add turbo or nitrous to any motor and make at least 1 dyno pass before it blows up, well whoopeyy dooo, if you wanna compete stock internals vs stock internals, then lets go, if you wanna add turbo then go ahead, your not even in the same class, dude you've got 4 cylinders, paid more, and are slower with the same amount of mods, I think its a big waist of time, and you guys do look very stupid when you get your asses dusted, looking like you cant explain how the *** you got beat, your cars SUCK!!!, if it comes down to mods, then duh, whoever'z got the deepest pockets WILL WIN!
