View Poll Results: Who Is Better For Suspension Parts
Multiple Choice Poll. Voters: 18. You may not vote on this poll
Some Questions Regarding T/A and PHB
I made a poll too, but who is better.. BMR or UMI?
But anyways here are my questions.
1) What is the advantage of having an adj T/A?
2) What is the advantage of having a non adj T/A?
3) What is the advantage of having an adj PHB?
4) What is the advantage of having a non adj PHB?
i think the non adj T/A is a good b/c it is alredy made so that the pinion angle is at -2*. Any more, wouldn't that be bad? That is why i am thinking of amybe getting a non-adj T/A
Also what is a better T/A, body mounted or trans mounted?
For the PHB, i dunno much about them. With the non adj it is what it is, but with the adj one you can center your rear right? How do you even go about getting it centerd?
BTW i am still at stcok ride height too.
Thanks i jsut purchased a BMR STB and DSSL.....
1.T/A ADJ.: Sometimes the best pinion angle for your particular needs is more, or less than -2.
2.T/A N/ADJ.:It cost less.
3. PHB ADJ.: Stronger than stock, allows you to center the rear-end, and as a result the ability to run wider wheel/tires with less chance of rubbing.
4.PHB N/ADJ.:Stronger than stock, less expensive than adj.t/a.
5.T/A body mt.:best for drag racing.
6. T/A trans mt.: autocross, daily driver,corner carving.
7.PHB adj.:IMO, get the on car adjustable model that you adj. from one side.
8. Adjusting ADJ.PHB:Back car up on ramps(rhino ramps),block the frt. wheels . With your hand/fingers check to see which side has a larger tire to fender lip gap. For example:If the drivers side has a larger gap, then adjust the bar longer, or the passenger side then adjust it shorter. So then just the PHB and the check the tire to fender lip gap until it seems equal on both sides, and then tighten the PHB adjuster down, and you're done!
From what i gathered/read it all depends on you application
the T/A for me i am going to stick with a non adj not sure if i am going to do body mounted or trans mounted T/A. Non adj b/c -2* for pinion angle is perfect and whether to get body or trans mounted. Well I maybe do the track 1 or 2 times. So i would think that the trans mount T/A would suite me quite nice.
Now for PHB, i am running 17X10.5 in the rear with 315/35/17 tires WITH NOT FITMENT ISSUES at all. So again maybe a non adj PHB may work for me?
Is there any drawback going with NON ADJ T/A and PHB?
FWIW, I'm going adj. for every piece I'm buying. I'd rather have the ability to adjust something if need be, or later down the road, than be SOL and have to buy another piece because I didn't get adj in the first place.
Based on the information you have supplied I think the non-adjust. items would work very well for you.
If I can help anymore please ask.
Thank you!
Ryan
i THINK I'm not positive, but aftermarket rears sometimes require some adjustment for a better overall fit. That's something to consider too. I would just call UMI or Sam Strano and pick their brains for a while. Very helpful.
Usually with the 315 tires we recommend a adjustable panhard bar due to tire rubbing in the inside fenderwell... however if you are not experiencing any rubbing with your current set-up the non-adjust. should work just fine.
Thank you!
Ryan
Thank you!
Ryan
I too was surprised that my 315's did not rub at all
But like i said i go to the track maybe 2x a year, my car is not my DD so drive it on the street sort of aggressively..
So that is why i think that a non adj T/A is perfect body mounted. It will give me -2* of pinion angle which is perfect. The only thing that worries me is that the body mounted T/A, upon a rather aggresive take off will it bump the under garriage? I know my friend has an adj T/A can not remember if it is body/trans mounted. But ANY take off and it THUDS under the car. Man i hate that..
And a non adj panhard bar is perfect i dont need to center my rear b/c my tires do not rub, plus i dont plan on lowering my car
If you are installing a Moser 9" soon I recommend both an adjustable panhard bar and a adjust. torque arm. Usually the 9" aftermarket rear end never sits centered in the vehicle after the installation... the panhard bar will allow you to center the rear end by moving it side to side and the torque arm would allow you to re-adjust the pinion angle... also our non-adjust. torque arm unfortunately will not mount to the Moser 9" with out grinding... all our other arms are just fine.
My suggestion is to look at a Strange 12-Bolt... they fit much better then any other brand and alwayus sit nice and centered in the vehicle with out adjusting. Also the non-adjust. Panhard bar and torque arm would mount right up to it with no issues.
Does that help some?
The best of both worlds would be a relocated full length torque arm. The full length torque arm keeps the handling and with our relocation mount you are able to remove any kind of stress from the transmission tail shaft. Here is an example. If you have any questions please feel free to ask
