LCA DIFFICULT BENT FRAME? *tech question
Are you doing this with the car backed up on ramps (easy way) or with the car up on jack stands and wheels removed?
Where are you seeing the gap in the t tops? In the window sealing area? You can adjust the t tops around in many different places. This is probably not a good indication of a bent frame due to all the possible adjustments.
To do that you have to remove the t tops trim and then undo a small hex head screw on the t top window channel. This will make it fill up the entire space if you are having an issue where the t top weather strip isn't filling up those little pockets on the main weather strip.
That area of the car is kind of hard to use as a gauge.
i believe the lcas have to be installed with the vehicle at ride height removing them one at a time. make sure both bolts are loose to properly align the lcas. unless you got into an accident or absolutely suck at driving, your 3.8 didn't bend ****.
there is almost no easier mod.
