opinons on these rotors?
LS1TECH Sponsor
I can't make that recommendation for you. Both are excellent quality rotors, not made god-knows-where junk. You can't go wrong either way.
You have to decide based on whether or not you want the look of the ATE's, or the coating, or not. If not, go Brembo which cost a bit less. The value with the coating added, and structural integrity of the ATE's is superior for a slotted rotor. They cost a lot less then slotted Brembo's do, and don't give up a lick of durability and are IMO superior to the more deeply slotted, and sharp cornered slots of the Brembo Slotteds.
Comes down to blank vs. ATE slotted in the end. Neither is bad, neither is "better". Take your pick. I carry both.
__________________
LS1TECH Sponsor
Whatever I happened to have on my shelf at the time I needed them.
Sorry, don't mean to confuse you. If you don't care, then run the less costly Brembo's!!!!
__________________
Tech Resident
From what I gather, the performance is the same. If you want the ATE's, you're only paying for the looks, nothing more. If you like the looks and the looks alone are worth the extra money, get the ATE's. Otherwise, save your money and get the Brembo's.
Why not go for these instead?
http://www.ws6project.com/user_stor/...oducts_id=1598
They're pretty popular.
One of the sponsors, I believe BSI Brakes, sells a whole package for $299 - cryogenically hardened rotors (drilled/slotted or just slotted) with Hawk HPS pads. I think for another $50 he gives you stainless steel braided brake lines. Check him out.
https://ls1tech.com/forums/suspensio...brake-faq.html
And read about the drilled or slotted rotors... Towards the bottom of the page
-Mark
-Mark
LS1TECH Sponsor
Not all of that is 100% accurate. For instance it's pretty vague and lumps a lot of various "slotted" rotors together when it says they will eat pads. Some can if they are not chamfered correctly.
A quality rotor like an ATE isn't going to act like a cheese-grater on your rotor. Cheap rotors that warp and have sharp edges to the slots can as you can catch the edge of the pad on the edge of a slot. But a good true rotor surfact with precision slots (vs. some guy banging holes in cheap rotors and selling them as premium parts) won't give you a hassle.
And fwiw, racing does have more performance oriented uses for slotting. However, if the slots ate pads that badly you'd not find rotors like that on endurance road-racing cars....
I ask everyone to take pretty much anything they read on web (no matter who it comes from) to take the information as information, not gospel. There are various details that can make something regarded are right (or wrong) suddenly wrong (or right).
__________________
And I completely agree.
But the OP was looking for a new rotor that would last longer than the set he has now. And considering his already cracked and slotted and drilled is USUALLY for racing and extreme duty. His application doesnt really apply...
LS1TECH Sponsor
Got ya... Just wanted to kick that out as often "stickies" are taken as 100% gospel.
For the record, in general--
The biggest issue with cheap rotors is they are more prone to warping, and if they are drilled and/or slotted that means more prone to cracking. And cheaper rotors are generally cheaper because they are made from less tough metal (and often less of it).
The inferior grade metal, along with less mass to absorb heat is what causes cheap rotors to be cheap. And what causes them to wear faster (even if they don't warp).
Think about the pounding brakes take. As much power as a Bugatti Veyron has (1001+ HP) and AWD. It takes 119 feet to do a 0-60 in 2.5 seconds. That's a car that run a 1/4 mile in 10.1 seconds @ 142mph....
Meanwhile our cars stop from 60 in a distance not much more that than the 119 feet it takes that SUPER powerful car to get to 60 mph. Think about how much braking horsepower the brakes give you. All that abuse and is put through the rotors.
There are cheap brakes, just like cheap tires, or cheap gas, or cheap spark plugs, or cheap anything else.....
__________________
#32
LS1TECH Sponsor
A good rotor is a good rotor. The trouble is not all the rotors out there are good. And meeting OE spec doesn't mean much because most of us know the stock front rotors are very prone to warping.
__________________
#34
LS1TECH Sponsor
That's what I'm trying to tell you.... Because the ATE's aren't p.o.s. rotors, and the slots aren't done like everyone else does, you aren't giving up anything in terms for performance (well such a small bit of swept area that you'd never notice).
Pick the one you prefer. They'll both work just as well as the other.
__________________
#37
#39
