Springs advice
the gap is about 3"... i already have Koni shocks at home and wanted to lower it at the same time since I'm changing the shocks. I was thinking about a 1,5-2" drop. Now the problem I have: I live in Germany and I can only use springs made in germany otherwise i can't get them through TUV. So the only springs i found til now are the Eibachs (LS1 Pro Kit) or Vogtlands. I've read that the rear eibachs are too soft and sag after a while what about vogtlands? Does anyone know their rate? (I've already looked a lot but couldn't find the Vogtland spring rate)
But I'll call the guy who's gonna put the springs/shocks on my car and then get it through TUV and ask if he thinks he can get Sam's springs through TUV too since they're made in Germany...
Still have a question that's not answered. What are the rates of Vogtlands and does somebody have pics of lowered cars with them?
Are you saying they are going to inspect your car, see the white springs and know they are after market? Why not spray paint them black and say they are stock, or some kind of SLP option?
Heres info on the Vogtlands:
Working spring rates:
Front: 440 lb./in. - 542 lb./in.
Rear: 183 lb./in. - 228 lb./in.
Rear seems overly stiff.
If he thinks mine will pass, I'd happily send you a set. I have customers in Germany running on them... I don't know how they get by with them if it's a big problem. My springs are made by Vogtland, and are made in Germany. While that's not a TUV pass, you might find that Vogtland has TUV approval as a company and it won't be an issue. I don't know what else to tell you.
I know that this post doesn't directly relate to the parts enquired here, however I thought that it may serve at least two purposes:
1. Holger (the one who posted the details) has imported US made items and performed the appropriate measures to get them German TUV approved.
2. He might be able to chime in here and give some recommendations on how to get German manufactured items not necessarily marketed for German road use to be TUV approved.
He's actually been quite helpful in explaining to me through several PM's on how German TUV approval for custom items works.
I'd also like to note that I kind of agree with what Sam states, so hopefully his springs should be TUV roadworthy. They're not as low as other springs, but from what I've seen on several cars which had them, it's actually a good thing that they're not lower than what they are (for performance reasons).
@Sam: thanks. I think I'll buy the LT1 Pro Kit.
@Foxxtron: thanks. That guy posted in a german board too. But it all kinda sounds like a tale for me.
I called that guy and he said he has a TUV report for Eibach springs and he could get them through TUV. Vogtland doesn't offer a TUV report for these springs, means they're out of question.
I guess I'll have to take Eibachs.
