Energy Suspension Bushings
Old 12-06-2008, 06:38 PM
philsblwnz28's Avatar
Exclamation Energy Suspension Bushings
I just got done putting Front and Rear Sway bar bushings and link bushings in a 99 Z28. They are all Energy Suspension (red ones). Do you think I will notice a big difference? I also installed both outer tie rod ends.
Old 12-07-2008, 09:19 AM
leadfoot4's Avatar
I wouldn't say a BIG difference, but a subtle improvement. Unless, of course, your original ones were pretty well worn. Then you'd notice a big improvement.
Old 12-07-2008, 08:48 PM
00cls1camaross's Avatar
I didn't notice anything. The nice thing is, they don't squeak like my stock ones did. I did all the bushings on the front and rear sway bar.
Old 12-07-2008, 09:03 PM
Intercooler2's Avatar
If you are lowered the front takes a different size.
Old 12-10-2008, 08:24 AM
Can anyone confirm the lengths?
Old 12-10-2008, 08:31 AM
NOBR8KSS's Avatar
My bushings were cracked and stuck to the sway bars when I replaced mine. It was a large improvement when I switched to the poly bushings.
I'm lowered and didn't have to use a different size. I suppose you could make an argument for a shorter end-link, but it isn't necessary and doesn't affect suspension geometry.
Old 12-10-2008, 12:13 PM
Sam didn't tell my anything when i ordered my Shocks and Lowering Springs from him. I don't think the size makes a difference.
Old 12-10-2008, 01:52 PM
Kingc8r's Avatar
I need to do this upgrade. Where did you guys buy them from. Local auto store, sponsor, other?
Old 12-10-2008, 02:15 PM
I got mine from BMR and with a 1" drop you need .25" shorter end-links. You could also cut the spacers down if needed but according to BMR (and it makes sense) you need a shorter spacer to correct the drop. Don't know why Sam doesn't mention it. Rear bushings aren't affected.
Old 12-11-2008, 02:10 AM
KILLER-LS1's Avatar
you guys know the red ones are meant for show cars right? the black ones are injected with graphite and squeak less!! get the black ones!
Old 12-11-2008, 06:06 AM
leadfoot4's Avatar
Yes, it does. After lowering the car, you may have to shorten the length of the sway bar's end links. The object is to keep the "arms" of the bar as close as possible to being paralell with the road surface.
Old 12-11-2008, 10:52 AM
Old 12-11-2008, 09:01 PM
My end-link kit BMR sent for their 1" drop springs is according to this an A-Body kit. The measurement is 2 5/8" PN 9.8117G
Old 12-11-2008, 10:25 PM
99Bluz28's Avatar
Lightbulb
For the front, 1/2 of whatever the drop actually is.
For the rear end links you'll need them 1" shorter for a 1' drop,etc......
You can get the end links at just about any auto parts store.
Or just cut the center tube to the length needed, and add washers on the end to make-up the difference.
Old 12-11-2008, 11:00 PM
I got mine at AUTO ZONE.
Old 12-12-2008, 07:30 AM
leadfoot4's Avatar
True, however, when you start getting links that are really short, you run into weird angles between the mounting points on the axle and the frame, especially in the rear.
I installed links in the rear of my car that were slightly shorter, to compensate for the roughly 1.25" drop, but if I wanted to keep the links perpendicular to the ground, I'd have to cut th frame brackets and weld them in at a different angle. Mine are at somewhat of a funky angle, but I don't weld, so I'm living with them as is....
Old 12-12-2008, 07:38 AM
crossroads's Avatar
thats exactly what i was thinking. I lowered mine about 1.50 and put on spohn sway bars and didnt cut the tubes
Old 12-12-2008, 09:24 AM
bobbyd's Avatar
sweet so they have them at autozone I gotta get a transmission mount.
Old 12-12-2008, 04:01 PM
Sam told me not to worry about it today
Old 12-12-2008, 05:13 PM
LS1TECH Sponsor
Sam Strano's Avatar
Unless the car is slammed, don't bother. I don't. YMMV
__________________
Quick Reply: Energy Suspension Bushings
