need help picking lca
Boxed our tubular won't matter... tubular is going to be lighter and offer offer more tire clearance is most cases over a boxed set-up. We always use tubular control arms on all our vehicles. Chrome Molt material has a higher tensile and yield strength than mild steel... this allows us to use thinner wall material to build our items resulting in a lighter product. Weight and some strength are what you will gain by using Chrome Moly steel... we don't recommend chrome moly unless the vehicle is a single digit drag car.
Our control arms can be seen here- http://www.umiperformance.com/produc...ategory_id=119
If you have any questions please ask and I will be glad to help. Thank you!
Ryan
Hello, you only need adjustable lca's if you have to center your wheels front to back. Lowering requires an adjustable pan hard bar. We also offer tubular, billet, boxed and moly lca's. We are having a 25% off christmas sale. If you have any questions please give me a call.
http://www.bmrfabrication.com/
I buy into the theory that poly poly can bind up the rear axle personally so I would only go that route if handling didn't matter and I was drag racing.
I'd go with a poly/rod personally if I were changing arms so the poly end could hopefully dampen the sound a little bit more than rod ends at both sides while the rod end will allow free axle movement. Though I race and I'm sticking with stock LCA's with moog bushings (haven't installed them yet so no feedback)
I'm a Strano customer and tend to rely a little more heavily on his opinions and he recommends and sells UMI stuff. So I'd go with UMI. BMR stuff is probably not much different honestly, though they haven't had the poly/rod combo (until recently I think....). UMI and BMR are heavily involved sponsors on LS1Tech so you definitely will have great customer support from them.
A single set has lived through 3 seasons of hard racing on a customer's car and still no visible wear or play. VERY impressed
http://www.youtube.com/watch?v=Yz_euA_bi0E
:yikes:
and from the other side of the camera
http://www.hart-photography.com/phot...ewImage=566565
http://www.hart-photography.com/phot...ewImage=567030
http://www.hart-photography.com/phot...ewImage=566640
http://www.hart-photography.com/phot...ewImage=567324
http://www.hart-photography.com/phot...ewImage=566726
http://www.hart-photography.com/phot...ewImage=567052
http://www.hart-photography.com/phot...ewImage=566730
Yes like mention the adjustable is only used to center the rear end... lowering the vehicle will not effect the length of the control arm.
If I can help anymore please ask. Thank you!
Ryan
Good to see the arms are holding up to off road abuse as well
