Tokico Blues...
https://ls1tech.com/forums/10436831-post20.html
The rear or no better (probably worse). They are progressive and have a max rate of 137lbs/in (stock is 114lbs/in). They are rated at 1.4" lower than stock, so the stock springs compressed 1.4" would be exerting 159lbs of force per spring.
Here is a pic of the rear suspension travel on a car lowered with the Prokit (which is supposed to be .2" higher than sportlines).
http://aycu25.webshots.com/image/323...4278257_rs.jpg
You're not finding any other that give a 1.8" drop because that doesn't give our cars enough suspension travel to work right.
You might be one of the few that turn out to be happy with sportlines but you need to ask yourself, is it worth it to spend the money twice if you don't like the setup?
Since the "look" is the only thing you care about lowering on stock shocks wont kill you, you might just want to try a set of springs with the stock shocks and see if you can deal with it.
Keep in mind no shock can make up for really crappy spring rates and too much of a drop...
https://ls1tech.com/forums/suspensio...r-springs.html
I can only tell you what I've heard/seen myself with the other shocks, and I would personally recommend Konis (wouldn't own another Fbody without them now). Above I wrote what I've seen with the KYB's, which are supposed to be only other shock for our cars that work well with lowering springs.
If you want an in depth analysis on what shocks to go with and why, I would call up Sam like I said in my previous post. You really can't go wrong with talking to a SCCA national champ (who's used all the said springs and shocks) about your car's suspension.
