Help "My rear end is setting over at least 0.5 inches"
Hey guys I recently got a 95 M6 TA and the rear end is setting over towards the drivers side about 0.5 inches. It has barely rubbed the under coating off a spot in the inner wheel well on the passanger side. The car had a used factory torque arm put on it one time because the previous owner "my buddy" was driving around town and his factory one just broke "it was weird but I was there lol". So last night I put it on a lift expecting to find this used torque to be bent and be the problem but when I looked it seemed to be ok. It had a slight curve to it but the more I thought about it it seems that my torque arm on my 98 car has slight curve also. I checked out the rest of the suspension and it was all stock and seemed to be fine. The car is at factory ride height but is on a set of 17X9.5 C6 Zo6 Wheels. Does any one have any ideals what else it could be?
Thanks, Chase
Thanks, Chase
same problem here w my third gen not as noticable w stock rubber under it but as soon as the slicks go on its very obvious i just cut my ph to the lenght i needed and duct taped it back together
So even though the car is not lowered you still think an adjustable ph bar would be the fix? It is over pretty bad and when I say at least half an inch I mean at least lol.
,Chase
,Chase
Like everyone (except the duct tape guy
) has mentioned all you need is an adjustable panhard rod.
We offer a variety of different types to fit a variety of applications. A link to our panhard bars can be found here:
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
