Panhard rods
Old Feb 21, 2009 | 08:45 PM
Texass683's Avatar
Default Panhard rods
Just wondering if some of yall can help me out, what is the best panhard bar out there for around $120. Thanks in advance.
Old Feb 21, 2009 | 09:07 PM
metalmechanic's Avatar
i have BMR Upper and Spohn Lower, they are mixed caused i didnt investigate enough when i bought the lower, didnt think of looking for the upper
Old Feb 21, 2009 | 10:53 PM
fast377's Avatar
You can get a good double rod ended one for that price used. I have a umi piece.
Old Feb 22, 2009 | 04:33 AM
v7guy's Avatar
I built one for about that price, easy and light.
Old Feb 22, 2009 | 06:41 AM
UMI Performance's Avatar
Hello,
Is this for a street car or a car that will see a lot of track use?
Let me know and I will be glad to make a recommendation based on that. We offer a variety of panhard bars at very good prices.
Thank you!
Ryan
Old Feb 22, 2009 | 11:39 AM
Texass683's Avatar
It will be for street DD use. I do get up to the canyons and mountains and do some twistys so I need something that will be good for that too. Thanks.
Originally Posted by UMI Performance
Hello,
Thank you!
Ryan
Old Feb 22, 2009 | 11:58 AM
BlueBird346's Avatar
BMR adj. is a good peice
Old Feb 22, 2009 | 12:53 PM
Hello,
Ok great. I recommend item # 2022 seen here- www.umiperformance.com/2022
This item is on-car adjustable and features a rod end on one end. The rod end allows the suspension to articulate correctly and prevents bind.. this is very important on the twisties. A panhard bar with polyurethane bushings on both ends could bind under certain loads. We do use a poly bushing set-up on one end... this is designed to absorb road noise and prevent them. I can't tell for sure but it appears your vehicle is lowered? Even if not you are at least running larger wheels and most likely larger tires. The adjustable panhard bar will allow you prevent any tire rubbing.
If that item is out of your price range we also offer these two- www.umiperformance.com/2021 and www.umiperformance.com/2029
If you have any additional questions please ask. Thank you!
Ryan
Old Feb 22, 2009 | 03:03 PM
Elliott's94Z's Avatar
Adj. UMI Panhard here. Very nice piece.
Old Feb 22, 2009 | 07:16 PM
BandDirector Blk98ZM6's Avatar
I've got the Edelbrock 5222 Adj. Panhard Rod from one of the 2 MAJOR mail-order parts catalogs and it was $112.95 I'm VERY happy with it! It is on-car adjustable and a very nice looking piece!
Old Feb 22, 2009 | 07:33 PM
koolaid_kid's Avatar
If you are constantly changing tires, on car adjustable makes sense. Otherwise, you adjust it once and forget it.
I have the UMI 2021 and it is a nice piece.
Old Feb 22, 2009 | 08:10 PM
Randy WS6's Avatar
BMR here
Old Feb 22, 2009 | 08:36 PM
35th SS's Avatar
UMI here rod/rod on both ends on both cars.built for the track.
Old Feb 23, 2009 | 12:51 AM
slow ride 02's Avatar
colemanracing.com $80.00
Old Feb 23, 2009 | 03:06 PM
BMR Tech's Avatar
Originally Posted by Randy WS6
BMR here
Thanks guys for the purchase
We also offer a variety of panhard rods for different applications. They can be found Here:
Panhard rods
If you have any questions regarding our products please feel free to ask...
Old Feb 23, 2009 | 04:19 PM
Sam Strano's Avatar
LS1TECH Sponsor
I'm with koolaid_kid. Given your price range, the 2021 would be the one I'd recommend. At $109 it's the most effective and strongest one in and around your range.
http://www.stranoparts.com/partdetai...D=67&ModelID=7
Why? Well, first it's got less deflection than any of the versions that use two poly bushings (the rod end doesn't deflect). And it's stronger than the types that have an adjuster partially up the bar.
__________________
