suspension question
Old Mar 12, 2009 | 10:52 PM
RNation0001's Avatar
Default suspension question
whats the first thing i should buy for the suspension as far as best thing for helping hook off the line?
Old Mar 12, 2009 | 11:28 PM
AR15 guy's Avatar
Sticky tires....
I usually start with LCA's and panhard rod. That or an adjustable torque arm would be my vote.
Old Mar 13, 2009 | 01:12 AM
Fifedogg's Avatar
find some used LCA's for cheap on here and look into some good tires. You can start from there and keep adding more stuff like a Torque Arm, SubFrame Connectors etc.
Old Mar 14, 2009 | 12:34 AM
thanks guys i appreciate it
Old Mar 14, 2009 | 08:49 AM
01ssreda4's Avatar
you an M6 or auto??
Old Mar 14, 2009 | 02:32 PM
6 spd.
Old Mar 14, 2009 | 04:12 PM
plum krazy's Avatar
subframe connectors
Old Mar 14, 2009 | 04:24 PM
twitchtwice's Avatar
Originally Posted by plum krazy
subframe connectors
first purchase?
tires should be first on your list if you worried about hooking
Old Mar 14, 2009 | 08:13 PM
waldershrek's Avatar
Well I think it's a three way tie between, a torque arm, LCA's and brackets and SFC's as far as importance. Each one does something a little different and when they combine they work wonders for hooking. Obviously you'll need sticky tires too but they alone won't do it.
Old Mar 15, 2009 | 08:41 PM
30th6's Avatar
if you dont want to twist your car you need subfames before you get sticky tires.
Old Mar 16, 2009 | 09:13 AM
brians91formula's Avatar
I agree that SFC are very important even on a stock ls1 car. Would be one of my first mods.
Old Mar 16, 2009 | 09:17 AM
qwk93ta's Avatar
I've had them on every f-body I have owned.
Old Mar 17, 2009 | 12:55 AM
deerslayinrednek's Avatar
def a set of sticky tires......Last year I couldn't get my 95' to hook at all
Old Mar 17, 2009 | 07:24 AM
UMI Sales's Avatar
Thumbs up At the track...
Hello
I noticed that you are asking about what will help you hook up at the track! There is a lot of different routes you can go. But the best bang for the buck is a set of Lower Control Arm Relocation Brackets and Sub Frame Connectors. Do you have anything done to the suspension already??????If so what? Leave me know and I will be able to better assist you.
Thanks
Brad
