adjustable Vs. non. adj ?
Old Mar 15, 2009 | 08:39 PM
hawk584's Avatar
Default adjustable Vs. non. adj ?
just wondering what the pros and cons are between the two? other then price
Old Mar 15, 2009 | 09:09 PM
Ironxcross's Avatar
adjustable what
Old Mar 15, 2009 | 09:12 PM
98TAjwh's Avatar
i've heard that when it comes to suspension: "if there is an adjustable option, get it cuz you'll just end up buying it later anyways" i can't remember who told me that, but it makes sense.
Old Mar 15, 2009 | 09:32 PM
DlXlE's Avatar
+1 ^
Old Mar 16, 2009 | 05:45 AM
qwk93ta's Avatar
I bought adj. control arms because I plan on buying a 9" in the future and I have been told you are better off with adj. controls arms with an aftermarket rear.
Old Mar 16, 2009 | 07:26 AM
UMI Sales's Avatar
Thumbs up Moser Rear end Help!
Hello,
What we recommend is Adjustable control arms when someone is going to be using a Moser Rear. Moser's housing's are wider and that off sets the factory locations. So going with the adjustable arms allows you to use recenter the rear and eliminate binding problems. If you have any other questions feel free to ask and I will be glad to help!
Thanks
Brad
Old Mar 16, 2009 | 10:02 AM
ndfrsd6's Avatar
i always have bought adj.... better in the long run
Old Mar 16, 2009 | 10:28 AM
twitchtwice's Avatar
there is no point to buying non adjustable, may as well keep your stock stuff. the point of aftermarket is the ability to tweak things. long story short, buy adjustable. you will be changing things in your car so the adjustability is there.
Old Mar 17, 2009 | 10:19 AM
Bad Blue WS6's Avatar
Im one of those that bought Non -adj rear componets ,,,,while i have had no issues with my non adj pan hard (no settings, im stock ride, etc), i did install a moser 12 bolt,,now my rear Thrust Angle is out by .36, cause of the reasons mentioned by Brad in post #6 ,,, only way to fix is to get the adjustable control arms. Just wish they wernt a $200.00 item
Old Mar 18, 2009 | 08:59 PM
StealthFormula's Avatar
I have all non-adjustable UMI stuff. It all works good enough to cut high 1.6x 60's when I was just cam-only and full weight. I sort of wish I would have gotten adjustable since I one day want to do a crazy 396 N/A setup but money was tight at the time.
