car vibrate when i brake
I have a 2001 6spd Z28. When I put on the brake My begins to vibrate. It vibrate both when I slam on the brakes and just regular old braking. Please help!
That is your best bet because it will just happen again if you get them resurfaced. It's worth it to buy a higher quality rotor (I would recommend a blank) so you don't have this problem over and over again.
Didn't know that could happen, thanks. I knew that they needed to be torqued correctly, but not the whole warping of the rotors could be a reaction to it being wrong.
You can warp aluminum rims by improperly torquing them down, but I have never heard of the rotors. You would really need to bend the **** out of your rims for the force to pass through the rims and onto the rotors.
I had the same problem and i guess the person who owned my car before didnt put good brake pads on and warped in the inside of my from passenger side rotor pretty bad, heres a pick of the new and old pads on that side.
Anyone got a deal on some slotted and cross drilled rotors?
