Just dropped my motor in but still 8inch wheel gap!!!!
I replaced the K member with a a BMR....just got the new motor so I dropped it in thinking the wheel well gap should drop back close to normal. DIDNT MOVE!!!! Could my shocks be frozen from the car sitting so long with no weight?
It is more likley that the suspension is on a bind right now. All you need to do is roll the car back and fourth a few feet and the wheels whould return to the normal position. Then you will see the actual ride height of the car. After you roll it back a few feet, bounce the front of the car a few times then roll it back.
Good luck!
Good luck!
Drove the car around still extra space in the wells, i loosened the a-arm connections, and loaded the front end, even jumped up and down on the car, tightened them back up, still too much space, what can it be?
