Odd Noise
Recently I've noticed a thud noise coming from the right rear when hitting large pot holes or those nasty narrow but tall speed bumps. It also makes this sound occassionally when angling into a parking lot when turning right from a road where there is a dip. It almost sounds like the tire is coming up and hitting the rim of the wheel well. However, I know this isn't true as I can find no scrape marks on the edge of the tire. I've checked out the Bump backs (those rubber bumpers that stop the axle) they seem to have plenty of rubber left on them... It has an aftermarket cat back but it's had that for many years now and it's never been a problem. I can find no where it's making any kind of contact. Could it be the shocks? They aren't leaking and the car has very little mileage on it so it seems strange that the shocks would be bad?
I'm at a loss to figure out what it could be that's causing this strange sound, So, I thought I'd ask here for any suggestions or past experiences others may have had?
Here is a few suggestions! Check your bushings in the control arms (Maybe bad) and make sure all the hardware is tight! If you have any other questions feel free to ask and I will be glad to help.
Thanks
Brad
I'm going to take a closer look at it this afternoon to see what I discover...
I was looking at the Bump stops and they look plenty thick (about 3") but how thick is enough? If they are worn enough they could be just at the limit where it would let a tire hit the out edge of the wheel well, that's what I'm thinking? Those BFG KD T/A's even at the proper size are a tad larger tread width than the factory Goodyear Eagle F1-GS.
I just don't understand what it is that's making that noise? Anyhow I have a couple of Bump stops coming UPS in a few days maybe that will help? Never hurts to replace something that's getting old and will need replacing eventually. I also noticed the new ones are made from a different material (it's white not black like OEM) but they are OEM parts? Maybe they learned the old type just didn't last and changed to a better rubber compound for new OEM versions?
I'm begining to think it's a shock but I don't see where it's ever leaked? That of course doesn't mean it's still good...
